hey guys,
just doing some research before i get a set of G4 coilovers from just jap :D
i basically want a set that will go the lowest in ride height
its just for a street driven skyline R33 so spring rate cant be too stiff
basically ive looked around and the Tein coilovers dont drop the car height as much as the G4's so im asking if anyone knows of any brand coilover's that will drop the car lower than the G4's (currently only drop it max 12cm from stock)
looks like this on the lowest setting:
you help is most appreciated :)
thanks
hey guys,
just doing some research before i get a set of G4 coilovers from just jap :)
thanks
If you are planning on driving it around that low spring rates won't matter anyway as you are more or less on the bump stops.
I gather handling is not an objective.
Ever thought of bags?
hey guys,
Try doing a search, you will find feedback from quite a few guys who have tried and rejected G4's
The limit on height is not what spring/shock unit you use. What stops you is the suspension geometry, it turns to shit.
Impossible, the lower you go the higher spring rate you must have. Springs absorb impacts, from bumps, speed humps, pit holes, ripple strips etc etc. As you shorten the spring you reduce the amount of travel to absorb those impacts. If you run a soft spring rate it simply doesn't have enough resistence to absorb the impact and it slams into the bumps stops, pretty soon destroying them. Then the shock bottoms out and destruction of the internal valving occurs. There is no nothing to abosrkb the impacts so they are passed directly into the chassis, which starts to crack around the mounts. One day the cracks join up and a shiocjh shafts stick up though the bonnet.
Simple, remove springs and shocks and replace with 4" x 2" piece of timber, cut timber to desired height.
Evil handling, dangerous, slow accelerating and has no braking performance to speak of. But hey it looks good, to the uneducated, the rest of us laugh our heads off. :laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014:
Cheers
Gary
ok.. thanks for that. I will keep it in mind...
and ive did a search and read about the G4's being really stiff.. :P
edit** just realised 120mm is 4.7" lower from stock which is enough for me :)
thanks guys!!
looking for second hand set if anyone has one before i get a new set off just jap :D
thanks again!
Edited by McDrifto
freind of mine bought g4's for his car u13 bluebird (now sold) they werent all that stiff and they were extremely low and nowhere near the lowest setting.
but why would you want it that low?? would be a pain to drive you would have to stop at every speed hump and driveway.
more interested in the ride height :P
Maybe I wasn't blunt enough, you can't have an R33GTST that height (as in the picture) and expect anything other than very rough ride. That's the facts.
Cheers
Gary
thanks gary i edited my post and also read up on your posts on other threads when i did a search :D
basically i want a 2" drop from stock for street driving then be able to adjust it to be decked for show :P
wasnt planning on driving that low 24-7 :)
Response amended. You can't have a 2" drop in an R33GTST and expect anything other than a rough ride.
Cheers
Gary
i've got buddy club coilovers in my r34, couldnt be happier. Gives a nice firm feel, and is dampner adjustable to soften it up if need be.
Has HEAPS of height adjustment, shits all over my bros teins in his r33, so for a show look you could dump it quite easily to the height in the photo, but like previously said, it would be on bump stops the whole time and would ride like poo which doesnt make any sence when you just spent 2k on decent suspension to make the car ride better
Go coilovers, not g4, and you'll be happy
If your interested I have a set of adjustable coil-overs in my GTR. At the moment I have them raised as high as possible and the car is just street legal. Droped down they would give you the kind of look your after. Not sure about the tyre wear though. Let me know if your interested.
    • This is the territory of the "Stage 1/2/3 Golf GTI/R" or otherwise off the shelf tune with (relative to before) minor mods. It's easier now. Downpipe and Tune and boom, big increases. Stage 1 OEM+ is where it's at. This is where the niche evolved into and it's really easy to see why. It's rare to even NEED to consider changing turbos or going to aftermarket ECU's or building bottom ends for more power. Stage 1-2-3 will get you a LONG WAY. Civic Type R turbo GR Yaris/Corolla Anything with B58 (MKV Supra/x40i) Anything BMW in General Anything Audi in General Any turbo AMG RenaultSport Turbo offerings Korean Elantra N/I30N Ecoboost Mustangs Focus RS? List goes on. I would argue in the future it won't even need to go on... M3P is pretty rapid out of the box...
    • There is a way, but it's not with the same cars. You need to find the same vintage of car, that we had. Realistically, that was an affordable car with aftermarket parts around. So what people need to find is a car that had a decent base in its day, and can be modified. They're looking for a car year make of 2010 to 2015 really... Aus could have done it if Holden didn't fold as V8 commodores were cheap, and if Ford didn't get expensive thanks to COVID, then you could cheaply play with FG Barras. Realistically, those are just a bit heavier, four door skylines. I'm sure the US and UK have similar cars they could find.
    • Haha I do that.. thats when it chirps..The bit point for me is almost non-existent. Otherwise I stall it. But yes, in terms of performance, the clutch is solid af.
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
