R33 Rb25 Vs. R34 Rb25
old240sx
 Share
I recently bought a s13 and have been wanting to do a 25neo swap. I live in the us so neo motors are a rarity and the only place I can find them are from those sketchy canadians up north. And from them who knows what your gonna get. I can find r33 25's all day even in the states for a little extra but I dont know the potential I would be missing out on. I've heard a lot of good things about the neo besides the price of clutches and was wondering your thoughts. From what I here if anyone would know about these motors it would be you guys.
I've read they also have solid lifters and the vvt as apposed to the r33's but I was wondering if any body has pushed them and if they really mad more reliable power than the r33's.
The NEO tends to make more power for the same amount of mods better breathing due to head package). They are both as reliable as each other but the Neos' tend to have lower mileage which helps.
Also consider the availability of aftermarket turbo kits and ECU's (ie Power FC). Mods for the 33 are more readily available and cheaper than for the 34. NB: PFC are discontinued for RB25's
well, for starters, I'm pretty sure the NEO's are fitted with RB26 rods from the factory so that would make them stronger.
They are also 9.3:1 Compression as opposed to the 9:1 compression of the R33 RB25
interesting, can anyone back this up?
turbo kits from R33 fit perfect on R34, i do it all the time with the trust kits.
doesn't the neo have both intake and exhaust NVCS?
also standard the NEO has smaller injectors than r33?
and a slightly better stock turbo...
both are good standard but the NEO would be the better choice because they're are generally newer.
Bloody net dropping out!!!!!
Here we go, I'll retype again...
NVCS is only on one cam.
They run narrow body injectors
Stock turbo is weaker when boosted due to nylon comp wheel, ceramic exhaust wheel like r33
Mate Ben has R34 GT-T
Stock engine
tomei poncams 260
800cc inj
044
fuel reg
z32
power fc
front mount
plazma man plenum
T04Z
363RWKW @22 psi Z32 starting to max out.
He has a built RB30 bottom end to swap in due to nos system he intends to use with setup, no bull.
The way I look at it is that it makes a bit more grunt in factory trim so that can't be a bad thing . The electronics running it are a bit more advanced so if you can get control of those then its tighter controls IMO .
I think the non hydraulic buckets are a bonus and will open up your choice of cam profiles . If you really want to I'm sure there are ways to get larger injectors into them .
Also don't write off RB26's if you can get them for reasonable money , a few people have used those in the US .
Further O/T . If I was over there I'd be doing a killer KA24DE-T because there are so many parts available for them and they are std (DE) in a USDM S14 anyway . I guess its a case of how much your prepared to pay to be different . I don't remember the exact cc figures for both KA24 and RB25 but there's probably only 100cc's in it if that .
Cheers A .
And an extra 2 cylinders bobbing away in the RB? Surley that counts for something?
 Share
