hey guys iv just finished putting an rb25 into my VL, and yesterday on first start up it hunted at idle quite badly, then sometimes the revvs dropped really low and it made a bit of a tapping or knocking from near the fuel reg. then i started it again last night, i didnt let it warm all the way up to running temp so not sure if it would have begun hunting again, but it just idled a bit high and not very smooth, with a very slight hunt. i have checked everywhere for a vacuum leak etc, i am only left with rather a sensor is screwin round or my BOV is leaking or something. any other causes of this? anyone who knows about these would be a huge help!
Edited by r32drifter1
https://www.sau.com.au/forums/topic/204942-some-quick-help-please/
Could be your air flow meter is not working properly (that's asuming your setup is still using an airflow meter) are you using a nissan ECU or an aftermarket item?
other possibility is the AAC valve is dirty..maybe.
thanks heaps for the quick reply guys, yeah airflow meter im not sure, i am using one of my old silver top rb20 because i was told they are the same? any chance thats the problem. and lol i dont know alot about these engines. the ACC were is it? there is a sensor and plug just below the idle control motor, a purple plug from memory, its a little damaged from transit, does that play a role in idling etc? oh and yer using standard rb25 ECU, ive tried spraying crc around looking for an air leak but im starting to get more convinced its not the problem
the import place that i bought my engine from. could it be making it run wrong?
quite possibly. i haven't looked at an rb20 motor to see if they use the same airflow meter. but if they don't it could be sending completely wrong voltages to the ecu which would definitely cause idling issues.
yeah its a S1, iv just found that DIY cleaning the AAC valve and realised that is the part which has a damaged plug on mine, that could probably be the reason yeh? are these a part only on rb25s? cause i have an rb20 and 30 manifold in my shed i could swapping if not!
unplug the AFm and start it up... if it idles fine then your AFM is the issue
*note, with the AFM unplugged the engine willacctually run and idle very well... but wont rev more thne 2000 ish rpm, where as an AFM that is plugged in but not hooked up to the intake pipe or popped off intercooler hose will run like shit.
the ecu limp home mode works with the AFM unplugged.
ok i have some more symptoms its got me confused now, ill try get some pics up if i dont get it fixed soon. i actually took it for a drive yesterday and it was wet so hard to really test, but it looses traction easy etc. but on grippy surface it doesnt want to go. it makes all the noises just doesnt accelerate like it should. also the idle hunting, it only does it when the car is warm, and if you gently accelerate it will stop. lastly on cold start up it wont revv at all, if you give it any throttle is just wants to die, and is a bit of a pig to get started cause of this. so yeah theres the million things wrong with it, anyone got any ideas?
yeah i have a feeling there is a faulty plug in my loom, which is involved in giving power to the fuel pump. hopefully that will fix the sluggishness, i dont understant why it would hunt and not revv untill warmed up. maybe some of the sensors take power from it too
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
    • The consult isn't even OBD1. It's a Nissan Consult. Proprietary.   Re read everything I've said. I specifically say, put down the laptop/tablet. Understand, and review the issue first. Logging voltages is the same as logging the converted value. Things like O2 that you say to log, is unusable for this, whether it be the voltage, or the value the ECU thinks.   The fact you don't know how to diagnose without looking at the computer, is exactly what I've said multiple times is the issue for why techs these days can't diagnose the fun issues with cars.
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
    • What basics? With these OBD1 ECUs it's not like the ECU will give you any real clues, it's not really doing any sanity checking of sensors/sensor data. My experience is actually a lot of sensors tend to be the source of the issue first and foremost, and checking everything gives you a direction to investigate. MAF/O2/STFT/LTFT should all kind of make sense. You can try little tricks of the trade like tapping the MAFs to see if it triggers a stumble, things like that. But once you've done a compression test knowing whether you have an air leak or fuel delivery problem is kind of hard to narrow down without sensor data. And you don't really know if all your sensors are making sense unless you can interrogate the ECU directly about what it's seeing for sensor data.
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
