hey guys iv just finished putting an rb25 into my VL, and yesterday on first start up it hunted at idle quite badly, then sometimes the revvs dropped really low and it made a bit of a tapping or knocking from near the fuel reg. then i started it again last night, i didnt let it warm all the way up to running temp so not sure if it would have begun hunting again, but it just idled a bit high and not very smooth, with a very slight hunt. i have checked everywhere for a vacuum leak etc, i am only left with rather a sensor is screwin round or my BOV is leaking or something. any other causes of this? anyone who knows about these would be a huge help!
Edited by r32drifter1
https://www.sau.com.au/forums/topic/204942-some-quick-help-please/
Could be your air flow meter is not working properly (that's asuming your setup is still using an airflow meter) are you using a nissan ECU or an aftermarket item?
other possibility is the AAC valve is dirty..maybe.
thanks heaps for the quick reply guys, yeah airflow meter im not sure, i am using one of my old silver top rb20 because i was told they are the same? any chance thats the problem. and lol i dont know alot about these engines. the ACC were is it? there is a sensor and plug just below the idle control motor, a purple plug from memory, its a little damaged from transit, does that play a role in idling etc? oh and yer using standard rb25 ECU, ive tried spraying crc around looking for an air leak but im starting to get more convinced its not the problem
the import place that i bought my engine from. could it be making it run wrong?
quite possibly. i haven't looked at an rb20 motor to see if they use the same airflow meter. but if they don't it could be sending completely wrong voltages to the ecu which would definitely cause idling issues.
yeah its a S1, iv just found that DIY cleaning the AAC valve and realised that is the part which has a damaged plug on mine, that could probably be the reason yeh? are these a part only on rb25s? cause i have an rb20 and 30 manifold in my shed i could swapping if not!
unplug the AFm and start it up... if it idles fine then your AFM is the issue
*note, with the AFM unplugged the engine willacctually run and idle very well... but wont rev more thne 2000 ish rpm, where as an AFM that is plugged in but not hooked up to the intake pipe or popped off intercooler hose will run like shit.
the ecu limp home mode works with the AFM unplugged.
ok i have some more symptoms its got me confused now, ill try get some pics up if i dont get it fixed soon. i actually took it for a drive yesterday and it was wet so hard to really test, but it looses traction easy etc. but on grippy surface it doesnt want to go. it makes all the noises just doesnt accelerate like it should. also the idle hunting, it only does it when the car is warm, and if you gently accelerate it will stop. lastly on cold start up it wont revv at all, if you give it any throttle is just wants to die, and is a bit of a pig to get started cause of this. so yeah theres the million things wrong with it, anyone got any ideas?
yeah i have a feeling there is a faulty plug in my loom, which is involved in giving power to the fuel pump. hopefully that will fix the sluggishness, i dont understant why it would hunt and not revv untill warmed up. maybe some of the sensors take power from it too
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
