hey guys.... i have noticed that on my high mount manifold..when pullin out the turbo.. that the external gate gasket from the manifold to the external gate is bung... and am ringing all over the shop and no one has this gasket...could n e body help me out with a gasket place in the S.E suburbs... thanx guys!!!... and just quickly... should there be a gasket inbetween the dump pipe and turbine... mine doesnt have one... should it??...
thanx
alex
https://www.sau.com.au/forums/topic/204963-external-gate-gasket/
What type of manifold / gasket combination do you have?
im not quite sure what u mean....but the joint from the turbine to the dumpipe (high mounted) its like 5 bolts circular and both surfaces just are smooothed over...almost looked machined uno... im just gonna make my own gasket from those sheets at repco.... how could it go wrong??!!
He means what brand is your external gate?
The gasket sheet at repco isn't exhaust gasket material so it will just burn off the instant it gets hot.
Black silicone is not temp rated high enough to put on a manifold. Plus it's not o2 sensor compatible so it will kill the sensor
get some gasket material from an exhaust shop.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
