Hey im just guessing here but wouldnt that gaffer tape they use to temorarily fix up smashed panels at the v8 supercars work well, they could just tape up all round the bonnet cos that crap sticks real well, but as i said im just guessing here..
The way i've done it, is get some of that metal cable with plastic coating around it... cut 2 lengths, make 2 loops, thread one on the bonnet and one around the radiator support or something solid, then get like a hook/clasp that you can clip on/off easy..... Should only cost a few dollars to get the stuff to do it and about 5mins...
i dont know how much i trust the plastic coated wire anymore. i have done it as tight as i can and have forgotten to undo it before opening the bonnet a couple of times and its come undone. i imagine the forces when the bonnet is up 5in at at speed would be more than that. It is the cheapest and its acceptable so just do it... :P
i would goto bunnings and ask for the stainless steel cabling though, since you dont need much anyways.
Much much stronger, and get the little U clamps for it too. I think thats what there called.
Edited by Mick
If this is a standard car with a bonnet release in the car and a release under the bonnet to get the bonnet up, then it has 2 catches.
If you still want a bit more, use a leather belt teethered under to bonnet to the bumper brakets or maybe the under body tow point some how.
I have a climbing clip with the catch in, on a piece of steel wire. The steel wire is screwed into somewhere near the bonnet release utilising a screw already there and the climbing clip loops through the bonnet loop that the standard bonnet release uses. Easy and cheap :no:
Other guys in the club have used their SAU lanyard looped through.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 😂
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
    • also, we need to know which solution worked....
