Thats exactly it SLED, minimum seat pressure that works. Which comes down to experience what does.
The RB26 heads run 50lbs seat pressure standard; the rb25 runs very close to that but uses the heavier hydraulic lifters. As you would know heavier valve train requires more seat/open pressure to control the valves.
Mine being setup so loose because they really didn't have any experience with the rb25 head has cost me a lot of money and what really got up my nose is when I sent it back to be fixed up I was charged quite a lot.
Such is life; given time they will get the know how of what does and doesn't work with the rb25 heads.
Typically its known that ~70lbs of seat pressure with the hydraulic rb25 head works very well.
R32Abuser; if you do get a motor built up by them ensure they restrict the oil delivered to the head.
Without a dry sump setup its really the only way to control the oil being dumped in the head and filling your catch can under constant high rpm as without a decent vac setup the oil cannot return to the sump quick enough.
I run a single 1.5mm up front and blocked rear. Works extremely well.
Don't get me wrong Miltons do awesome work; its just a slight lack of experience with one motor type that left me a little unstuck. They are getting in to the drift scene so no doubt a lot of R&D will be done.
In saying all that there is ALWAYS some one who's had a bad run with a workshop from time to time. :/
The experience wasn't bad just the outcome which has been frustrating when I had to go else where to seek advice and get the problem finally rectified.
I'm going to be running a 1mm ristrictor with the other blocked off but I dont have hydrolic lifters so I'm a little better off. you can also make a return from your catchcan to your sump so you dont loose all your oil at full RPM.
Its worth giving Darren at lewis engines a call as he can set up the best combinations and tricks to keep engines going strong in drift or street conditions.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
