Hey,
As everyone says "search and you shall find" but in a ruder tone. All this info has been covered its just a matter of finding it. Anyways i did mine about a week or 2 ago and it went like this:
Oil: Motul 4100 turbolight 10W/40, 5L $49.99 @ autobarn.
Oil filter: Ryco Z145 $15.80 @ autobarn (i think i got 10% off).
As for the filter you can get a nissan genuine filter, $15 i think.
After alot of research thats what i ended up using and in future will use the motul oil and genuine nissan filter. Theres no point in using motul 300v unless your heading for the tracks.
Incase your going to ask i bought genuine coolant from nissan and bought spark plugs and a fuel filter from autobarn so if you want to know the numbers for them let me know.
CASTROL EDGE 10w60 as recomended to me by a Drift Mechanic I run it in my RB25DET R34 last couple off services and used to always in my old S14A Silvia SR20DET try to stick to a genuine Nissan oil filter if you can!!!! Also my girlfriend has a DC5 Type R Integra had some V-Tec trouble changed the oil with this and fixed it.
Very nice, them dc5s are hot! Anyways back to the original post, what was also covered was, any decent full synthetic will do if ur gonna drop the oil every 5000kms.
Usually you only have VTEC trouble when the oil gets low :)
Seems to me like the old oil/filter combo comes down to personal preference. What works for you is fine.
Iv always used Magnatec in my cars, previous DC2 Type R, regularly tracked. And i never had any problems of pressure loss due to heat etc etc. So i continue to use it in my R33 GTS25t. So far so good. I read so many things bout people saying it is shit, but its always what the person has "heard" or "read". Never actually had any hard evidence of it being shit. Haha
Regular 5000km changes of oil.filter = :D
Edited by gotRICE?
Preferbley find an oil that works well and stick to it.
I had to find an oil that as not too think / too thin.
I have tried Martini Full Synthetic 10W 40 (Bit too thin and burned off too easily) / Valvaline 20W 50 (TOO THICK!!... no go) Shell Helex 15W 50, OK but in the long run no good.
Final Mobil Sythetic S 10W 40 which was a semi sythetic oil and the car runs very smooth.
Edited by (00)SKYLINE(00)
A 10w-60 is good for the track but to thick for street driven cars you should be looking at a 10w-40 or lower.
Any synthetic - Motul, Redline, Royal purple, Mobil 1, Castrol, Penrite.
i use the nw DRIFT oil filters, $19 magnet, nut on end for easy removal etc.. best filter around.
oh never use penrite sin stuff sucks in rb's.... used in customer cars when they supplied it excessive pressure drop and excess noise after 2000kms when other oils are fine, i stick to redline 10w40 and motul 10w-40 300v
^^^ 3/4 sounds right.
Thanks, I'll try it out this weekend.
Ryco Z145a Filters. ~10$
Mobil 1 5w-50w fully syn. ~68$
Usually dont need to buy the expensive filters as most likely u will change them every 5000kms. But if u want to keep them longer then go for it :happy:
I was running Apexi UFO's (~$15-$20 USD) on my ER34 RB25DET(Neo) and BCNR33 RB26DETT. Now I have these Sard Sports Mag+ Filters SMF00(~$15-$20 USD). Hopefully they'll fit and workout alright.
Mobil 1 Full Synthetic 15w-50 Extended Performance $8 USD a liter.
Edited by chak8080
Running German Castrol 5w-40 in an R32 GTR, filter oem
Still trying to figure out why people use a 10-20w in thier cars unless your racing? The most engine damage is done starting the engine cold the lower the first digit the better. A 10w oil is thicker at startup compared to a 0w or 5w. No oil gives total lubrication when cold but hence the oil companies are leaning towards lower first digit oils now e.g 0w. The second number is the viscosity of the oil at operating temps, 40 is good for skylines unless racing in hot conditions. Also its better to use an API rating of SL or SM rather than SJ which is stated in the oem manual as the SL and SM are a better oil using the latest technology and wernt around when SJ was popular. You will get better results in regards to maximum cam plus lifter wear, sludge build up, high temperature volatility amongst alot of other things with an API rating of SL or SM over SJ. SM should be better than SL
Motor oil that is labeled for RACING ONLY is not usable for every day driving. Often these have more additives that are toxic to your catalytic converters and the environment. These oils generally do not have detergents. Use these oils if you plan on taking your engine apart and cleaning it every few weeks
This site is very helpul explaining oils
http://63.240.161.99/motoroil/index.html
    • Also did some work to the shed and a massive clean out of stuff. It's now got a small fab/dirty room and has helped keep shed cleaner. Built some new work benches and re organised things also got a TV out there so good having something playing while working on the cars. Got a pedestal drill and linisher off a mate that need to pick up too.
    • First thought, have your current injectors flow tested. If they test fine, keep the diagnostics going. It's not the injectors. If the injectors are the issue, find some new or used (cleaned and flow tested) injectors.  While I really love a good excuse to get a modern ECU installed, just needing new injectors probably isn't a good enough reason to do so.
    • A bit from column A, B and C. Mainly C   Update time, after deciding it was time to tick off a bucket list goal I finished up full time at MSR and have gotten back behind the wheel and making progress on the S15. Goal has been to drive Bathurst at an event and I have had my entry accepted for Challenge Bathurst in November. Since I don't want to go unprepared I need it running to test and get comfortable.  Been chipping away at it and started by stripping inside, getting it all cleaned and sealing some holes up. With stripping inside I removed the whole wiring loom and found a few surprises.......... its pretty butchered and shit branching and I'm not a fan of the haltech fuse boxes so it's all out and trying to come up with a plan to rewire it all either new fuse/relay box or pdm.  I haven't been happy with how I did the intercooler mounting and been wanting to tuck it up under rad support. O e issue with that is headlights will need a decent trim or get replacement covers. Took the time to mount it with some stand off's and new hardware. Stands are some m8 button bolts, washer, aluminium tube and factory radiator top mount rubbers. It's nice and solid also stiffens rad support which still requires some trimming. Bonus of factory rad mounting is used all factory hoses just need to weld a pressure cap to radiator now. Got sensor block and fuel filter mounted. Plan today is to get vac lines all sorted with push in nylon tube and design oil cooler mounting solution.  Been driving BRZ a heap and went out to Morgan Park for time attack and went pretty well for a wet day. https://youtu.be/gAlQgcQpWj4?si=kojOAOjhhX_X3AXR Getting pretty comfortable in it now and want to do a few more bits to it but restraining myself as don't need 2 race cars at the moment.
    • @sunsetR33 There is obviously a huge culture gap here. There is nothing in place like this in Australia, where if you fit a Mines branded pipe and later replace it with a Jun branded pipe, both pipes are essentially identical - BAM - huge penalties! Where is the Mines pipe?? You can't have a Jun pipe when you said you had a Mines pipe!  Makes no sense to me. Surely makes no sense to anyone else here either.  I'm sure a lot of us would agree that our registration/engineering system is pretty stupid at times, but it's not that stupid.  *** More serious question here. If you replace a factory rubber hose with a silicone hose, is the car illegally on the road now? Does it become legal if you have certification of what brand the silicone hose is? Then would it become illegal again if you replaced that silicone hose with a difference brand of silicone hose? And then would it become legal again if you had certification of the new brand of silicone hose?  I really want to know that answer to that question.
    • Good you making progress with this rig. Aluminium welding is painful to learn, have you got a pedal as I found it so much easier with one. If that's the AMG I think it is, you would working with Benny?
