Item: 2 x Super Light 19row Oil Coolers 29.5cm (W) 24cm (H) Approx
Age: one year
Condition: excellent
Price: $50ea plus shipping
To Fit: (anything)
Contact: Trent 0419 059220
Comments:
These coolers are perfect for those who want maximum cooling at a budget, we used two mounted where the A/C condesor used to be and they fit perfect. They are as new and have only had the BEST oil run through them.
the only reason i swapped them out was due to lack of space in the new setup, i have used twin smaller versions outto the side.
Does it come with oil lines?
not for 50, but i think i may have an old relocator kit in the shed... prolly want 150 for the lot... i will have to check though first.
Please pm me as i have 1 left and some-one says they are going to pay for it, NYTSKY if the second one falls thru it is yours.
I will take the last one if you have the relocator kit if it will fit rb?
Cheers David
At this stage there is only one left and it is waiting on payment, i will update the post later today with information in regards to whether or not i recieved it.
    • The interesting part of tests like IM240 is they measure the exhaust output. But they never measure the gases going into the engine... Imagine doing the test in a densely populated city with higher CO2 levels around... Instant disadvantage...
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
