does any body have any recomendations or advice of what brand to get or who to get it through.?
im after factual answers also - not just your generelised "i've never had an rb26, or a nissan for that matter but you should get brand MOQ cos i read about it on myspace and hot4's magazine.." kind of crap..
okay thanks - go for it..
https://www.sau.com.au/forums/topic/205042-wtb-sump-extention/
hey man
im in the same boat. i have done some research and have seen most friends with gtr's using the hi octance racing aluminium 8L sumps. They are bigger than the trust ones.
Hi octane also make them in cast steel now too. They wanted $700 just for the sump and $1200 all up if you send your standard sump and they will weld it up and modify the oil pick up.
The aluminium one was $1500 all up......
im still tossing up which way to go. Already have a tomei pump. Just need the rocker cover baffles, which they sell to. or you can get the mines ones from greenline.
They other thing is the oil restrictor in the block (lucky i have it already) and they other issue is drilling out the head to return/drain the oil back to the sump. I didnt do this so im spewing. I have read on here that its important to have.
i guess you could probably do a search on here and read more.
Good luck
HiOctane one is great, but about 3 times the price of the Trust sump extension, which has been used on many track cars and proven to work just fine.
http://www.skylinesaustralia.com/forums/Fs...st-t206631.html
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
