1-BNR32t
27-towlie
31-DRD-00F
34-MANG
33-RB20tR32, Bluprint
35-Stinkypoo
36-vietorious
37-sl33py
38-Into Oblivian
39-N1GTR
40-tm r33
41-TiTan
42-allthewaytotheskyline
43-Leech
44-Donnan, Evil33
45-Baconer
46-LadyBytes, Sauce
47-R3sp3ct
48-a20089
49-Ex!$t3nZ
52-Tarmac-
53-Bullet32
60-FATAZZ
65-Datto260Z
  • Replies 59
I say.... 51!!!!!
1-BNR32t
27-towlie
31-DRD-00F
34-MANG
35-Stinkypoo
36-vietorious
37-sl33py
38-Into Oblivian
39-N1GTR
40-tm r33
41-TiTan
43-Leech
44-Donnan, Evil33
45-Baconer
46-LadyBytes, Sauce
47-R3sp3ct
48-a20089
49-Ex!$t3nZ
51-DriftGTS
52-Tarmac-
53-Bullet32
60-FATAZZ
65-Datto260Z
Careful boy, I'm finding it hard seeing you getting through any course sub 2 minutes at the moment :)
Sub 2 minutes?? - Come to Wakefield with us one day and you'll find out first hand how quick a real driver is Steve :ninja:
Wow really? Turismo will be there? :)
I got a ride in Scotsmans 33GTR last year at their DECA, man that was insane! Absolutely ball tearing!
How about at Texi I hop in on a ride with you, and you see if you can scare me? :ninja:
1-BNR32t
27-towlie
31-DRD-00F
35-Stinkypoo
36-vietorious
37-sl33py
38-Into Oblivian
39-N1GTR
40-tm r33
41-TiTan
43-Leech
44-Donnan, Evil33
45-Baconer
46-LadyBytes, Sauce
47-R3sp3ct
48-a20089
49-Ex!$t3nZ
52-Tarmac-
53-Bullet32
60-FATAZZ
65-Datto260Z
Hope your willing to ship that half case :thumbsup:
For out of state Competitors I will wait til texikhana or some event and bring you your half a case
Buy the way tooheys extra dry or Crownies
1-BNR32t
24-Donnan
27-towlie
31-DRD-00F
35-Stinkypoo
36-vietorious
37-sl33py
38-Into Oblivian
39-N1GTR
40-tm r33
41-TiTan
43-Leech
44-Evil33
45-Baconer
46-LadyBytes, Sauce
47-R3sp3ct
48-a20089
49-Ex!$t3nZ
52-Tarmac-
53-Bullet32
60-FATAZZ
65-Datto260Z
I retract my previous estimate and hope the starlet is only running on diesel, lol.
PS Pat probably thinks that we are all joking; poor innocent child hahahaha!
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
