Hey all,
I'm planning on getting a r34 Gtt around June but i have an insurance question.
I'll be 21 when i get the car and i live in Canberra.
My problem is this...
In november last year i had a small micro sleep due to stress of exams while i was driving and crashed my car into the side railing. Nothing serious but the damage was more than the car was insured for (it was just a Hyundai Lantra 95 model). The insurance was under NRMA and was handled by my parents but it is recorded that I was the one that caused the accident.
Now how much of a problem does this pose for me? I'm assuming this would need to be declared right? I'm thinking Just Car.
Edited by snoopy4eva
https://www.sau.com.au/forums/topic/205099-insurance-problem-question/
Your Premium being 21 is going to be huge, its turbo and you have had an accident and its am import as well. I would expect no less then $3000 a year for full comp on a GTT. Justcar would be the way to go. I am 22 and justcar was the only company that would insure my gtst and it was $1900 but i had never had an accident.
I would just ring around its free to get a quote
I've just insured my R34 GT-V with Shannons I'm 49 & it cost me just over a $1000 (twice my commodore's premium), you can pay by the month with Shannons & it doesn't cost any more. NRMA was about $1200 or $1300 to pay by the month Shannons was cheaper than Just Car.
ok i just gave them a call and they said i'm looking at $2900. Which is better than i was expecting.
Not declaring the accident would be illegal right?
it would be f**king stupid... might as well just burn the $2900 and drive round uninsured
    • Details: Turbo Borg Warner EFR 9180 with 1.05 rear housing Upgraded TurboSmart integrated BOV Sanded and powdercoated compressor cover in gloss black Elbow welded with wiggins clamp Speed Sensor(Not included) (Can include oil drain(heat wrapped + titanium intake pipe with almost new filter for a tad extra). Manifold: 6 Boost RB26/30 twin scroll manifold  e-MAP ports drilled into both scrolls(I was using the TAARKS EMAP KIT) Turbo is in excellent condition. Always used Penrite 15w50 Racing oil(Changed less then 2000ks). Also using the Turbosmart OP regulator and filter. Downpipe: 4inch Stainless steel with VBand inlet and outlet clamps(included) Heat wrapped Dual ports for Dyno/Wideband usage Will throw in free 2.5 inch intercooler pipe(2.5inch From turbo outlet to 3.5 inch intercooler) - Powder coated black. Turbo made 563rwkw on mainline hub dyno at around 24-25psi boost - Pump fuel. Will def make over 600kw on e85. Didn't bother as my e-MAP was through the roof with my setup sitting past the choke line. I have a cnc ported and fully built head on my 3.2. Turbine speed saw max of around 109k rpm. I'm running this on my R32 GTR, with AC, and the original power steering pump. The manifold clears the AC lines, ABS, and everything else. Although I had new AC lines because I just wanted new ones and I heat wrapped them as well. This will make more power on a slightly lower capacity motor with a higher PR. And I have since upgraded to a G45-1500. Have pics and videos if need be.  Absolutely nothing wrong with setup. Turbo is in perfect condition. No shaft play or oil leaks at all. All the work was professionally done. The transient response of this is fkn amazing. I cannot rave more about this turbo. If I wasn't chasing 4 figures, I would have kept it. $5000 NZ. Located: Auckland, New Zealand.
    • I particularly like the look of the John Player Special team. (Thumbnail isn't different but hit play for the clip)
    • Such a cool collection of cars back then.
    • Mystery solved, thanks bro Bit of a strange mix, but i dont mind it, still looks good.
    • nah no problems with bearings or hubs.  just the water pump leak and my AC death
