Hey all,
I'm planning on getting a r34 Gtt around June but i have an insurance question.
I'll be 21 when i get the car and i live in Canberra.
My problem is this...
In november last year i had a small micro sleep due to stress of exams while i was driving and crashed my car into the side railing. Nothing serious but the damage was more than the car was insured for (it was just a Hyundai Lantra 95 model). The insurance was under NRMA and was handled by my parents but it is recorded that I was the one that caused the accident.
Now how much of a problem does this pose for me? I'm assuming this would need to be declared right? I'm thinking Just Car.
Edited by snoopy4eva
https://www.sau.com.au/forums/topic/205099-insurance-problem-question/
Your Premium being 21 is going to be huge, its turbo and you have had an accident and its am import as well. I would expect no less then $3000 a year for full comp on a GTT. Justcar would be the way to go. I am 22 and justcar was the only company that would insure my gtst and it was $1900 but i had never had an accident.
I would just ring around its free to get a quote
I've just insured my R34 GT-V with Shannons I'm 49 & it cost me just over a $1000 (twice my commodore's premium), you can pay by the month with Shannons & it doesn't cost any more. NRMA was about $1200 or $1300 to pay by the month Shannons was cheaper than Just Car.
ok i just gave them a call and they said i'm looking at $2900. Which is better than i was expecting.
Not declaring the accident would be illegal right?
it would be f**king stupid... might as well just burn the $2900 and drive round uninsured
    • It's impossible to convey what it will feel like to get the right torque. But you can develop a feel for it. A 900mm breaker bar is.....f**king huge. I only use a normal ~400mm one. But with 900mm being very nearly a metre, and the right torque being in the order of 100Nm, then you're going to need a bit over 100N of force, which is about 10 kg. So if you practice using the bar pulling up, instead of pushing down, then it will be about the same effort as lifting a 10kg bucket of water. That's what the pressure against your fingers should feel like. Ish. If you use a more typical length breaker, then it's about twice that. So a good 20 litre bucket, or a little bit more.
    • Also, if anyone has a torque wrench around Williams Landing area and can lend it to me for like 5 mins - I got 4 bottles of Furphy left and I’ll throw that in with a Happy meal 😂
    • So today I decided to bleed my brake fluid, which meant to the wheels came off the car at my garage for the first time. I only had a 90cm breaker bar with me and I noticed that some 1 or 2 lug nuts were a bit hard to get loose (from when the shop did the coilovers) Now.... when it came to putting them back on, I didn't want to put all my weight and overtighten them. So I hand tightened as much as possible and then put normal pressure on the edge of the breaker bar and tightened it until I couldn't turn it anymore without putting in an effort. Do you think that is tight enough? Or is that still too tight?  They are tighter than finger tight. Last thing I want is to have them strip or warp sh*t. But hard times mean I can't just go down to Supercheap and get a torque wrench 🥺
    • Dunno what to tell you, when I look at it on Consult I can see this warmup timing map kicking in around 40C coolant temp and it sticks around for a while:  At part throttle on the normal base timing map it peaks around ~43 degrees of timing or something like that, this warmup timing map drops it to like 12-15 degrees.
    • I don't think that's what you're seeing. Something else doing that. The only time I've seen it get so retarded is when it's trying to control idle (in which case we're not talking about mapped timing tagets anyway) and when there is an extreme coolant temperature sensor fault. The RB26 ECU is essentially the same as the 20 ECU and I knew that ging inside out. There is no facility for it to retard that heavily on cold start. The OEMs never used to do it back then. I mean, shit, the catalyst is abotu 3 miles down the exhaust anyway. Early light-off was just a twinkle in some EPA arsehole's eye back then, not a regular engine control strategy.
