Hey all, have done an R33 GTS Auto to RB25DET and manual gearbox, my question is with the brakes. I have to upgrade to GTST brakes, but to get it legally engineered do I need to go to the 5 stud bolt pattern or will the 4 stud suffice as long as calipers are changed?
https://www.sau.com.au/forums/topic/205121-engineering-question/
Calipers cant be changed without hubs, the bolt holes don't match up i believe.
Also disks wont match the calipers width.
So you need hubs with 5 studs to fit those calipers. Its not the worlds hardest job, as long as you have a breaker bar of some description. ie gal pipe.
it is my understanding that if a certain engine was offered in the same body from the factory then you dont need an engineers report.... IE 6cyl->350 chev in a HT kingswood or say changing a deisel gemini to a 2l gasoline engine its not required....so i cant see the diff
This is the reply I got from vicroads when asking about a ca18det into a ca18de silvia for my gf
Change of Engine
1. Replacement engine is identical to the original engine, or is an
option allowed by the manufacturer for the same model vehicle
The optional engine must be offered in Australia by the vehicle
manufacturer as an option for that vehicle (or certified variants). The
change of engine may be recorded by VicRoads provided that the
registered operator or a motor mechanic, or dealer in that make of
vehicle or an Automotive Engineer signs a declaration certifying the
engine is optional for the vehicle model, and that all modifications
made by the manufacturer for the same vehicle model with that optional
engine, have been completed.
But then as a silvia was never offered in australia so...
But sounds as though an engineer at least has to look at it
Engineer will need the brakes done, about the stud pattern, you'd need to ask the engineer that
Being its an import - VicRoads will send you to an engineer 9 times outta 10 as they dont want to pass judgement on imports etc.
If it was a AUS car - piece of piss, but ye. Imports are a pain for that
Thanks guys, I believe the bolt patterns should line up for the calipers, will guess I will find out soon enough. The main reason I ask is that I really dont wamt to get new wheels as the ones on it are quite expensive. Im going to have a hell of a time here in Vic as I have just come from queensland, and compared to Victoria the modification rules are seeming to be very strict. Eg my inlet alone has PWR front mount FMIC, Pod Filter, modded plenum and aftermarket BOV. And the ECU, well I guess I will have trouble transfering rego etc.
How strict is a roadworthy on modification issues, are they concerned with mods or just the safety aspects alone (hence the safety cert)??
the engine number prefix is the same....so i would simply fit the engine...then go to vic roads and have them sight the engine number....then thats it...obviously change the brakes for safety's sake...
This is how we got an N/A car registered with a turbo motor.
Yeah I reckon so.
if he has insurance and wants to keep it he has no choice.
im the worlds biggest fan of moving plates and numbers around but somethings things need to be done corectley :/
im the worlds biggest fan of moving plates and numbers around but somethings things need to be done corectley :)
Who said anything about moving plates and numbers around?????Vic roads dont have anything to tell them a vehicle has forced induction.
An engine block is an engine block and the numbers say that its an RB25 so wheres the problem?
Edited by ylwgtr2
    • I have copied the images in the original post from photobucket to the SAU servers to make sure they stay available.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
