1992 Nissan S13 180SX - SR20DET
I am in the process of building another car and this one must go to make way for the new bits and pieces.
The car has only recently been rebuilt and has lots of new parts, new paint etc.
The car has recently been resprayed by Primal garage and all the guards were rolled to fit the wide wheels. The car also has the following new parts fitted within the last 5,000km's:
Make: Nissan
Model: S13 180SX
Milage: 131,000
Transmission: Manual
Colour: Gunmetal Grey
Complied? Yes
RWC supplied? Yes
Currently registered?Yes
Price: $15,900 ONO
Contact: Greg 0401 554 476
Comments / Modifications:
Full URAS body kit,
DriftTek 17x 9.5" rims with brand new tyres all round,
Whiteline rear swaybar,
TEIN front castor arms,
Trust oil cooler kit,
Nismo thermostat,
R33 GTS-T front brakes,
GKTECH coilovers,
GKTECH rear traction rods,
GKTECH rear camber arms,
GKTECH toe rod stabilizer,
GKTECH rear toe rods,
GKTECH solid rear subframe bushes,
GKTECH deep dish steering wheel,
GKTECH intercooler,
GKTECH Cam gears,
GKTECH twin thermo fans,
GKTECH stainless steel manifold,
GKTECH stainless steel turbo back exhaust,
GKTECH Rocker arm stoppers,
GTi-R turbo,
Braided turbo lines,
Walbro fuel pump,
Dr. Drift boost controller,
Dr. Drift remapped ECU (making around 180rwkw's),
New waterpump,
All new belts in engine bay,
Trust gearknob,
Blitz boost gauge,
Type X front parkers,
GTR seats in the front,
Pioneer head unit with JL Audio front splits, Kenwood 4 channel amp and Pioneer rear 6x9's.
    • Fk me, I guess next time I will try to use the onsite attachments feature. I find it hard to work with so far though because I can't move the images to where I want them to be. I will try to make a separate post with just images. As for lifting. The work I need to do for now involves the exhaust and engine mainly, so the arm covering the jacking points is not a problem. But I don't want to bend in the whole sill or underfloor by lifting the car at the original jack points. I found some rubber blocks, 125 by 125 with a 10mm wide and 10mm deep cutout, which I'm hoping will work for not hitting the jacking rail. The sidemember, as seen in the service manual, are the rectangular frame rails that come from the front of the car and go alongside the gearbox and downpipe. Those that get crushed inwards if you use them for a floorjack. They are already slightly bent in from being used to hoist by other people. I think cutting off the jacking points and welding or bolting on a reinforcement plate along the sill might not be a dumb idea. Or is it dumb?     A 2 post hoist is what I'm gonna work with, but not for any underbody work, just leaky engine and exhaust work so far. Depends on what else I find that might need immediate attention. For metalwork on the sills I think I'd just bring the car to a panel beater. What's your take on getting rid of the original jacking rails and putting reinforcement plates along the sills?
    • Yeah titanium always looks cool but I don't need that, just regular pipes would be fine. But I am really struggling to find any full hardpipe kit that is still for sale.
    • Saruthewhite hasn’t been on our site since November 2016 sorry mate
    • Note when Duncan says that, he means "when you're not using the correct lifting points on the sills, because you want to work on the sills. A 2 post hoist is not appropriate for everything anyway, and working on the sills is a good example of that, because the arms go under ths sills anyway. You're better off finding another way to support the car off the ground. Beyond that everything else D said is correct. Only the dedicated jacking points are the correct place to lift. Anywhere else is incorrect, extra caution and awareness must be used, etc etc.
