Hey guys im looking at getting some 18 inch rims for my 32 and when i went to test fit them they wouldn't go on the front as the tire was hitting against the upper control arm. the tire size was 18x45x245 if i was to put some 18x35x235's on there would they then fit??? what size rims and tires do others have on their 32's
https://www.sau.com.au/forums/topic/205137-rims-for-r32-gts-t/
I think you would need less offset for that width.. i.e. 9" wide with gtr offset (+20) would likely fit on the inside but hang outside the guard.
*shrug* I run 17x7.5, no need for bling round here brudda :P
Edited by bubba
*shrug* I run 17x7.5, no need for bling round here brudda :D
yeah i was thinking that i might need 18x8 rims with 235s on to stop from hitting the control arm (also i havent forgotten about your money just having trouble getting to the bank :P )
I ran 18x8 with 235's without too much hassle. I just needed a small spacer (5mm maybe? I didn't measure) to clear the brake calliper and all was sweet. Didn't even rub on the arch lining which surprised me a little.
alright i might just try putting some 235s on the front and see how it goes cheers
I don't think it would make anydifference... that extra inch of rom width is what's causing issues, 235 will be very stretched over a 9 inch wide rim. You won't be able to fit a 9 inch wide rim on there without a reasonable sized spacer or low offset rims. If you already have the rims I'd suggest the spacer option.
alright i have some spacers already so ill try putting them on its only the tyre that is hitting the control arm though not the rim
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
