Hey all just thought id mention the new parts shop opening in Hobart. Right in town. Watchorn street, little one wayer that runs from liverpool to bathurst. Anyway i went up for a look today but hasnt quite opened yet. Its called... SLIP & GRIP RACEGEAR.
From what ive heard from a bloke whos been in the shop already they have some pretty good gear. They will be the dealer down here for KTS suspension i know that much. Dont Know the name of the guy whos opening/owning but no doubt someone on here will. Did a search and doesnt seem like anyone has mentioned it on here yet so ill start the Hype :)
Anyone know anymore about this...
https://www.sau.com.au/forums/topic/205150-slip-grip/
I spoke to an old school mate a while ago and he is opening the store.
He has quite a lot of knowledge in the import scene and is really having a crack!
I hope people support him, We can never have to many businesses like this around!
I wish him all the best. (Used to live with Dave and Sam Murray in Kingo - Tim Brown) some of you would know him.
https://www.sau.com.au/forums/topic/205150-slip-grip/#findComment-3635030
Pretty sure we already do, my condolences to whoever goes bust first. A town the size of Hobart can't support 3+ Import specific parts retailers.
And we all know none of them will go close to matching the prices you can buy stuff online for (e.g. via perfectrun etc).
However, good luck to them, personally in this instance I would LOVE to be wrong and see them all prosper.
Edited by floody
https://www.sau.com.au/forums/topic/205150-slip-grip/#findComment-3635818
I know Dave and sam well but dont think i know Tim. Sure people will tho
yer true hobart isnt the biggest of places... if his prices are right he might just do well tho. i wish him the best of luck also. ill try to support him.... when i get my new car that is.
https://www.sau.com.au/forums/topic/205150-slip-grip/#findComment-3636340
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
