  • Replies 569
Posted Images
32 gtrs - 18 - 25k mostly some of the nicer modded ones are into the 30s but not many. 33 gtrs can be had for as little as 24k ranging up into the 30s and the 34 gtrs have dropped down to around 45 - 50k for a non v spec model. v specs are still getting sold from 50 - 60k and then theirs the modified 34s/nur specs etc that are 70k+
Thats what I'm seeing on Carsales.com.au anyway. Definetly a good time to be lookin at 32s there seems to be alot more later modeled ones around 93/94s that are very clean. I'm looking to buy one come the new year :) fingers crossed.
Giant have you got anymore pics of this beast would love to see some more :P
  • 3 weeks later...
no more news!
mark has just finished moving house and i pushed my r35 in front for him to prepare for rally tas! so his machine gets to sit for awhile :D which he is not happy about.
so this is the r34 to date
if you need some where for it to sleep id be happy to give it a home for you for a while. got 200square meters of empty workshop i was thinking of leasing out. it can live with mine, although you get it back with a Chevy in it lol.
I was building mine with the intention of selling it, but know that its close to finished i dont think i could let anyone else have it. so the go-kart went on ebay instead.
yeah me too....you need to find some space and keep it. even once your fancy panys r34 and r35s are hooning around you will miss the antique feel of the vintage r32
dunc i have done f#@kall on the r34 , mark is a machine when he put his mind to it.
about the most i did was pull all the vinyl crap off the carbon boot , took about 6 hours! still got the bonnet to do:(
for some reason the japs had decided to vinyl sticker the body panels on the Tomei drag car instead of painting them.
She's lookin delicious Russ and Mark.
While I have you... I'm gonna grab some notes from Suncoast Classic Targa last year for our "leasurely drive" ok? Since you don't have anything sporty... I'm trying to finish some stuff off on the 32 if you wanna use that? I'll need Kel to do a re-tune though first.......
it should be a rocket Ben!
sounds great about the notes, i am happy to use your 32 if we can, thanks for the offer mate
i do have a road r32 but need to put the alternator back on it, only about a half hours work .
it's a beautiful car, i have only driven it about 500 kays in four years, rebuilt the engine too so could do with a run in!
i will speak to ya soon so we can talk about meeting up, i have been sick for 4 days , not at work & it's driving me mad.
yeah the r32 has gone to a new home! i love that car as you guys know lots of blood & sweat in it
the r34 is on the back burner until the r35 is complete in about a fortnight, which mark is not impressed about! :blink:
Its really gone? Oh no! Did it go to a queensland buyer or has it moved interstate? I bet you were sad to see it go
So the R34 hasnt changed at all since the last update in this thread? Ive really enjoyed reading this thread :blink:
Yep the 32 is really gone, gone to a really nice fella upnorth in Cairns, he will hopefully be doing the superlap series next year so the car will be around, mind you it will take him a while to get his head around it as he wont be driving it as often, i think with limited driving time it will take a while to be fast in it.
the r34 should kick off again reall soon and i'll post up some stuff then with the new bits and stuff.
  • 1 month later...
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
