Guessing the 3ltr was in for superlap? Sounds quieter than a 26 in that vid.
What block did you guys end up using, just a run of the mill nissan item, one of the 4wd blocks rips sells, or some other variant?
Impressive steering in the in-car vid too :banana:
Looks like it will scare some of the american/japanese workshop built cars once the attessa is sorted!
  • Replies 569
Posted Images
Impressive steering in the in-car vid too :P
yep it's 3ltr. and was 3ltr at superlap. it's far from quiet though, but it does sound different for sure.
most of the engine is from a tomei drag car (yellow 34), but obviously rebuilt. from memory it's a regular nissan rb30 block but mark or russ can confirm that.
it should be very good once sorted. i'm currently sussing out some more events for us in japan after the tsukuba time attack. we are looking to get into some of the best motoring style 5 lap tuner battles against other jap tuned pro class GTRs. now that would be something special. also want to run the car at fuji speedway. mark reckons with the right diffs it will pull 300km+++ at fuji and I don't doubt it. :D
lol, fark it wasn't me! ;)
yeah you are right mate. the yellow tomei R34 along with a couple of other cars was stolen by some lowlifes when it was for sale in aus. I'm not sure how much of the full story is public and I imagine it's a pretty touchy subject but the relevant part here is some stuff was recovered. and of that stuff mark and russ bought some of the bits. not much though. mainly just bonnet, boot and some engine stuff :D
Just spotted the car in the *new & improved* Auto Salon magazine.
The mag is still probably not to everyones' taste, but it's got good coverage of what the boys have been up to.
Congrats to Mark & Russ - great to see the interest and support the car is generating.
  • 1 month later...
NOTE:
You may have noticed this thread has been moved.
SAU Admin have decided to run a new section for "Projects, Overhauls and Build-ups"
As such your thread is a prime example of what we wanted to house in this section.
We have left links in the sections you originally posted also to allow easy access to the threads new home.
Any issues, please feel free to pm myself or N1GTR.
Cheers Col
did you buy it for Duncan the Autosalon whore ?
    • Welcome!  How long have you had it? And what colour is it?
    • "CAD" version 1.0 It will have a 15mm lip around the top for 6 × 5 or 6mm nutserts and fixtures (two on each of the three straight edges), and some pinch weld on any exposed edges, it has three mounting points, one of the power steering reservoir bolts, and two on the rad support, my 120mm hole saw will make short work of hole for the silicone joiner, with ample room for some pinch weld  I've also got enough Carbuilders "peel and stick" heat shield to cover the outside of it at the coolant expansion tank and on the engine side, as pictured, and internally on the lid and where the fuse box is, I've also got some thin, about 3mm, black 3M single sided sticky foam stuff that was left over after sealing some door drafts at home to help seal the lid As for the shape, it "sort of" matches the shape of the fuse box, so shouldn't look to "out of place" The lower area and hole for the intake will need pinch weld with a balloon on it to fully seal the hole and bottom of it, that will happen after it has been fabricated so I know exactly what size is required  Filter service has been trialed,  and so far it was a simple process  Just need to get some alloy, and then head into work to use the guillotine and break press in the workshop Hopefully it should be sorted in a week or two Guestimated outlay will be under a $50 for the stuff I don't have on hand (alloy, 6mm nutserts, the pinch weld, and wrinkle paint) Disclaimer: That's what the "voices in my head" are telling me how the filter box should end up getting done......lets see if they know what they are talking about
    • Have been polishing up the trailer rims as they had been sitting in the shed for a few years and are really in need of some love. This was after a couple of passes with chrome polish - coming up quite well ✅ .
    • Welcome aboard! Is your Skyline auto or manual? I'm assuming manual. Does it have any mods done yet?
    • Hey mate, the brown and grey plugs would usually go to the TPS, brown one goes on the bottom connector and grey is the top but isn't used unless the car is auto, your TPS looks different to mine though I've got a series 2 engine.
