hi guys.
im about to install a surge tank and an 044 pump (external). since the factory fitted fuel line in an r34 are black nylon from filter in the engine bay all the way to the tank, im not sure about cutting and joining the lines. i was going to just use barb push in hose type with clamp, but im not sure if you can do this with the nylon lines, i just assumed they would be rubber type.
for those guys who have done this please give me some advise.....surely you shouldnt have to run complete new lines under the car.
thanks
Justin
I'm just v.interested in other peoples answers!, as I've never heard (which doesn't mean a lot) of black nylon fuel lines...
Sure your not looking at a covering over the steel line? I wouldnt've thought Nylon is fuel resilient, nor capable of taking 5bar of pressure.
Edited by GeeTR
nylon? you mean rubber I think? Anyway, either A: buy a surge tank with push on hose fittings or B: it's new hose time. One thing I personally don't be cheep on is fuel system stuff, I use all teflon braided lines on mine as they keep the fuel smell out of the boot where are rubber ones seep and you get a boot that smells like fuel.
You can get push on hose - screw on adapters but getting a size to suit the already existing fuel line might be a bit hard....
If you don't want the smell, you can find somewhere under the car to fit a custom flat surge tank, or you can fit one in the boot with hard lines, or you can fit in a sealed box.
Iv heard some people with Teflon say they can still smell it; so not a 100% solution.
If your asking on a forum I assume your piecing it all together yourself. In the boot, rip the carpet out, remove the f.tank access plate and check the lines where they enter. I'm not sure bout 34's but I reckon you'll work it all out if you get under there and have a look.
Report back on these strange fuel lines too.
Edited by GeeTR
def no smell in mine since i got rid of rubber braid for teflon, used to stink the entire cabin out after sittting in the garage for a week but not even a hint of it now
to use rubber line you just need the hose tail fittings for the surge tank
std metal fuel lines are -6 OD
if u have AN fitings on ur surge tank, then just run normal braid/aeroquip rubber fuel hose with the AN fittings (-6) on the surge side and the earls hose clamps on the std line side
or if the surge is push on fittings, just use the aeroquip fuel hose (-6) and happy days :cheers:
have a browse on www.summitracing.com search for earls or aeroquip :ninja:
i unerstand everything you guys are saying, but your getting too indepth. first of all the car is an r34 it will only be used for drag. it maynot be regersted next time round, so im not worried about the legal side of things with surge tank and what type of line is used in the boot.
the surge tank has been made with 8mm hose tails, so no prob there. hoses push straight on to surge tank then clamp.....too easy.
here is the problem...ive taken off the inspection plate in the boot. worked out the pump line and fpr line. but they are factory fitted nylon or maybe teflon hoses all the way from the fuel filter in the engine bay to the tank...and at the tankthe hoses have a 90 degree plastic end and a push on type fitting that snaps into place.(i will take a pic tomorrow and post it up)
i know earlier skyline have rubber hoses but nissan have obviously upgraded this.
so my options are run whole new lines from fuel pressure regulator and supply filter back under the car to the surge tank, or find a way to conect rubber hose to the factory nylon hoses(which im hoping i can do via a barbed fitting, but not sure how that would go with the nylon/teflon hose)
you guys will get a better idea of what im saying when i put a pic up.
Plastic fuel lines eh? trick.
Al - Outa interest, why'd your mechanic replace just the return? (FPR -> tank)
Like you say Justin, if you cant find a way to secure a normal EFI hose onto the plastic fuel line, you might have to replace it all :D
*ponders* "plastic fuel lines, something new everyday"
Edited by GeeTR
these plastic type fuel hoses have actually been around for a while. im pretty sure later model camrys and comodores have them also. most late model cars also have the plastic push on fitting either side of the fuel filter
i really dont want to run new hoses because the factory ones are soo neat, they have purpose bends in them and run perfectly in clamps along the floor pan.
if i put a full rubber hose in place of the originals there is no way it would look as neat and conformed to the body.
anyway for those who havent seen the new plastic.nylon/teflon??? type of hose i will post a pic up this arvo.
thanks
Justin
hey mate, sounds like you best bet will be to pull out the std lines (assuming the plastic ones will hold there shape) take em to your local performance shop and get replica's made in ali fuel line. the ali stuff is extremely cheap, and you can either flare or solder the ends for screw on fittings
yeah thats a great idea. i will be having a talk to a few hose shops through the week and if there is no way to join this stuff the aluminium line bent to shape will be the way to go. i actually have a tube bender and pipe flaring kit at home, so i can do it all my self, theres just the alloy pipe for me to buy so it could work out to be very cost effective.
if anyone else has any other ideas on how to join this stuff, your input/ideas welcome.
thanks
Justin
Like you say Justin, if you cant find a way to secure a normal EFI hose onto the plastic fuel line, you might have to replace it all :)
I meant he replaced to line/s between from the boot to the engine bay. Not sure if it was just one line or both. :thanks:
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
