My god. Say what you mean, mean what you say and dont be mean saying it. Ppl are makign valid comments in this thread but seems people are cruising for an argument and from there it has lost the plot.
Can we get back on track ? :)
User banned.
The Mafia, next time around, don't bite back, as regardless of what the other user posted, some of your comments are equally unacceptable on this forum.
Next time report it first, don't react to it.
Ok lets get back to the turbo comparison..
Ive seen great things from the GT-RS turbo but i must say that the GT2835 has a slightly larger compressor wheel (correct me if im wrong, but thats what i seen last.. ) which will give it a larger amount of airflow for the same boost pressures so long as its in its efficiency range
That just took me 20 bloody minutes to clean up.
Behave yourselves your bloody children. For gods sake most of you know better than that.
EDIT: Just seen your post Nick, ive dealt warnings etc also so they can stay unless you have an issue?
Bumblebee I think the superior turbine/housing (gas flow wise) has more to offer than the trim size difference ie 52 vs 56 compressor trims . Also the GT-RS (2871R 52T) is a dead end as in there are no larger housings to put it in if you find it restrictive . Stupidly HKS never had the 0.86 version of the GT28 turbine housing made with the T3 flange .
At least with the 2835 Pro S you have two sizes to play with though virtually everyone who got the smaller one regretted it later on an RB25 .
At the end of the day its your money and your call , if it was me and cost was not a problem it would be the 2835 Pro in the 0.87 housing . If you were really worried about lag you could get the 0.68 housing , its still a larger ratio than the GT-RS's 0.64 but its in a GT30 based housing not a GT28 based one . The waste gate and dump design is far superior IMO to the GT28 type and that's what costs more to make .
Cheers A .
  • 4 months later...
sorry to revive an old thread but I've been through this dilemma recently and thought I would post the results... I decided on the HKS 2835 Pro S with the 0.68 housing (came with the kit so thought I would try it out first)
results were 244rwkw @ 13psi... clutch would not hold anymore power on the dyno... I can post a dyno chart if anybody is interested... mods are in the RB25 turbo upgrade sticky... turbo comes on a little later than the stock but this just makes it easier to putt around off boost... when you want the power its all there well before 4000rpm... I definately wouldn't desribe it as laggy... I'm VERY happy with the results, none of the whooshing sounds of the stocker either, just a jet like whine as it spools
can't wait to shove 20psi down its throat:)
lol
Hamish, do you get commission from promoting GT2835's? hehehehe :D (awesome results btw mate!)
Nick,
yeah it has awesome responce! man, Ive jsut read 3 threads now on these turbo's (GTRS and 2835) and now I wanna go for a drive lol!! But car is sleeping for superlap!
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
