Great stuff! A new thread specifically for Group A material.
I was thinking of scanning up an August 1989 article from CAR Australia where Paul Gover tests the R31 Gibson Motorsport Group A Skyline. When I next get access to a scanner I'll scan the article and post it up for everyone.
https://www.sau.com.au/forums/topic/205237-group-a-thread/#findComment-3634787
That sounds good!
https://www.sau.com.au/forums/topic/205237-group-a-thread/#findComment-3634985
That sounds good!
I'll get on to it when I can then. :yes:
Also, the focus in threads like these are on European and Australian Group A. Does anyone have any good pics of the Japanese Group A scene up until, say, the end of 1993?
Edited by ajrichar
https://www.sau.com.au/forums/topic/205237-group-a-thread/#findComment-3636074
To keep things even and balanced I decided to support Japan's leading manufacturer and present one of their Group A efforts. While I can appreciate the efforts the French have gone to with the Nissan brand Im afraid I prefer Japanese Toyota's a little more.
This information was taken from www.turbosupras.com along with the images.
In the heyday of Group A touring car racing Toyota campaigned the MA70 Supra as a contender in the over 3 litre category. In total 11 Group A MA70 Supras were built by TRD Japan and raced internationally. The car in the photos is number 7 of these 11 factory built cars and was raced on the Australian Group A touring car circuit by John Smith.
After the demise of the Group A category, John Smith was able to retain this vehicle rather than return it to TRD Japan. It is believed to be one of only 2 (the other wearing the blue BiJo/Fujitsu Ten livery as seen on various scale models) remaining intact.
Built to the group A formula the specifications of the car are a sign of the times.
Engine specification include: Cast magnesium 9 litre oil pan with matching high flow oil pump, Knife edged steel crank, N/A block hand picked from production line, Short skirt Mahle/TRD pistons, prepped rods and full floating pins.
Titanium fasteners were used throughout the motor. Extensive porting and re-shaping of the combustion chambers was performed with oversized titanium valves fitted. Camshafts were of 288 degree duration with their 10.88mm lift making shim under buckets a necessity along with 100lb valve springs. Titanium cam gears were also employed. Intake and exhaust manifolds were port matched. A 65mm throttle body was used. Fuel delivery consisted of 1000cc injectors and multiple fuel pumps. The ECU was MAP based rather than the traditional AFM which was found on the the production MA70 with the exception of the homologation Turbo A, of which 500 were made.
The turbocharger used on the race cars was a derivative of the CT-26 unit used on the Turbo A homologation production model but with a larger compressor wheel and more importantly a larger turbine housing and wheel. The intercooler was of a similar style core to the road going vehicles but with larger core area and larger piping. The turbine outlet employed a smaller separate outlet for the wastegate, similar to some of the aftermarket units currently available. Engine output was 580hp at the flywheel in qualifying trim (2 Bar) and the vehicle was able to achieve a maximum speed of 300km/hr on Conrod straight during the Bathurst 1000km Endurance race. In 1991 the car was running in 6th place late in the race until sidelined by a power steering failure of all things.
Drive train consisted of a Hollinger close ratio 5 speed with a direct 5th gear (all contained within the standard Toyota gearbox housing) and a TRD billet differential similar to the units commercially available but not identical, evidenced by the carrier not fitting into a standard housing explaining the slightly different housing on the race vehicle. Harrop 4 piston callipers with 15.5" (393mm) Rotors were fitted up front, as a result 18 x 12 " rims were required.
The vehicle was not as successful as its peers, notably the Ford Sierra and Nissan Skyline GTR, as its larger engine capacity required it to run at a higher kerb weight by the Group A regulations and also due to a lack of development relative to its competition.
https://www.sau.com.au/forums/topic/205237-group-a-thread/#findComment-3636410
Awesome car and Bloody quick as well.....passed the Sierra & me like we were standing still on EC Straight. Another car that was capable of shitting on the rest of the field...so why not put a weight restriction on it so that the Ford's and Holdens can win....bastards!!!! No disrespect to Sierra's...just the drivers...DJ for one.
P.S. To win the Supra would of only had to get past 2 R32 GTR's, 1 Holden, 1 Sierra, 1 BMW and maybe the R31? Was it in front of the R31 before it broke?
https://www.sau.com.au/forums/topic/205237-group-a-thread/#findComment-3637130
Afraid I don't know sorry. My memory struggles to go back 17 hours let alone 17 years.
All that info was lifted direct from turbosupras as credited.
Not Group A but I did happen across a little bit of info on the JZA80 Super GT Supra that TRD have in Australia currently
http://www.toyota.com.au/TRD/#main/motorsp...trdSupra:page=1
https://www.sau.com.au/forums/topic/205237-group-a-thread/#findComment-3637259
Blame Toyota, not the powers to be. The car was never competitive because it didnt suit the regs as well as some others. The displacement meant that it had to run a minumum weight and tyre size. The GTR was never intended to be a 2.6L, it was only after they realised that the weight of all the diffs etc were factored in they were never going to make the weight they wanted to...so upped the displacement to suit the maximum for its classification in Grp A. Turns out that the GTR had so much weight thrown at it they could have run a 3L anyway.
Like Larry Perkins used to say. The GTR was a Racing Car, the rest were Touring Cars which did not suit the regs as ideally as the GTR.
That said, i always liked the Supra. Its s shame that Mazda didnt try with the FC RX7. I suppose all their money was going into the Le Mans effort?
https://www.sau.com.au/forums/topic/205237-group-a-thread/#findComment-3637539
Well the Poms etc walked away from Grp A in 1990 didnt they? I think it was still running in Japan in 93, well at least loosely based on Grp A. Ditto the Germans as i recall in 92 they were still bringing out homologation spoilers for the BMWs
Yeah it was basically a dead parrot by 1992. Something a lot of people tend to forget/gloss over. EVen watching the '92 season it was a matter of how many laps went by until Longhurst punted Bowe. But by god the 3x20 minute heats format sucked teh wang.
https://www.sau.com.au/forums/topic/205237-group-a-thread/#findComment-3637601
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
