Craig you homo,,,thats a rubbish vid,,,wheres all the in car stuff???.
Neil.
sorry princess :D.....no incar stuff from Lakeside or EC......promise i'll get some incar from PI next year in the DR30 and R32!
  • 11 months later...
Hi all,
Thought I might post this...mainly for a little bit of sound.
This is the first shakedown after a complete driveline fresh'n up......rev's were set to 7,000rpm and boost to 20PSI and we were on old slick's.
Timing was 1:05's which imo was not to bad considering we didn't even know we were doing that time!
Hi all,
thanks for sharing - what a beautiful gtr & just the way i remember it as a kid on tv.
what boost & power level were they running in its day (prior to restriction)?
how much weight was saved in its race form?
Hey Craig, are you up this weekend? Are you bringing anything for me to drive?
yup....flying up Thursday.
I wont be playing though....Cazz had some last minute issues with the DR30.....pity because because this meeting is going to have some very quick cars. Dad will be running the GIO car again unless he meets with an accident!
@Marko....boost was set to 26PSI(ph34r.gif) with 8,500rpm in the 90/91 "apparently....but these motors are stupidly strong so who really knows what they did. Power level I would prefer to keep quite.....let's just say it's more than enough....weight is about 1,320kgs from memory.
Edited by Jetwreck
  • 1 month later...
Stumbled across this...anyone know who was piloting the R31?
I was there, the R31 was by far the fastest thing out there but he just couldnt keep it on the track with moves like that, he went of 2 or 3 times in that race and they also he to do a drive through (i guess to replicate a pit stop) when he got on it at the top of the exit leaving the pits it died, he rolled all the way down and onto the track and almost came to a stop before he got it started again, its an awesome car to watch and they will be back at sandown at the start of november.
guy's......thought you might like this.....this run is at 1.4bar!..........<1992 boost!
P.S. That HR31 at Sandown is our old car now owned by Cary McMahon........pretty sure he has his head around the car now....they were early days!
Edited by Jetwreck
what an amazing car & the pinnacle of all gtr's - case closed!
i came across this clip 2 weeks ago by accident & circulated it amongst my friends - such a beast.
JEM made a comment "We don't know engine specs all we know if thats a Gibson built engine. Turbo specs are similar to 2860 -5's but not identical"
do you have the same opinion in that the turbo's are closest to -5s if you were to match these with an off the shelf turbo?
442kw @ 1.4bar (only 20psi)...this is a true example of the R&D that went into this ATCC to make this level of power with 'smallish' turbo's - simply gobsmacking :worship:
What fuel is it running these days? I suspect that is was more power then they had in the day. Is it truly 1991 Spec?
Sunoco 260GT is the fuel we are running.........back in 91 the power levels were not that much greater than in 92.....in fact I have heard that the 92 tune was a lot more drivable and safe!.....we are not planning on running the higher boost unless needed!
yes Roy....this is truly 91 specthumbsup.gif....Only difference is the fuel and ECU......we had to move away from the original ECU as we could not source someone to do us new chips.....we would have stayed with the original one if we could have as it was a very good unit.
Thought I might add that this is the last of the GMS motors and it was brand new!....pity they did not supply the chips with it.
Edited by Jetwreck
  • 2 months later...
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
