My point is that is obviously difficult to drive the V8's well. You can see this by how many people struggle when they get into the series proper & by how many mistakes the development series drivers routinely make. I don't think that the difficulties are derived from the road cars - there isn't enough of them left to matter. I think it is a result of the regulations.
I would reckon any Group A car is by definition, more compromised by its factory origins than a V8.
LOL, isnt that what i said. It was what i was trying to say :thumbsup: Shouldbt be on the forum when had plenty of work on a busy Friday :blush:
LOL, isnt that what i said. It was what i was trying to say :wub: Shouldbt be on the forum when had plenty of work on a busy Friday :P
Ah, um, sorry. Me neither. :(
Saturdays at work suck too.
There was a good story from the VK Commodores at Spa in 1986. There is a book about it - Brock Moffat on the road to Spa.
  • 3 months later...
  • 4 weeks later...
http://au.youtube.com/watch?v=AsmTwm-glRU&...feature=related
^^^ How cool is it Skaife getting from 5th to 3rd before the first corner..... ON THE GRASS! LOL..... gee I miss those Group A days, three or four different brands of cars in the top 5.....
thats brilliant, i forgot about those days when i hated the skylines, how things change.
the ford had some poke down the straight though, and talk about giving the BMW a rev. and the VN boat, far out.
yeah that was classic but if the cars in front are blocking and you are going that much faster you have to go somewhere....
I'm 99% sure the got a black flag or penalty after the race for it though
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
