hey guys just thought i will share the process of my car. first thing i have done so far is just got my exhaust done by kermit and car is going into beyond customs on monday for the conversion.
while the conversion is being done i am also installing
5 HKS gauges
Apexi boost controller
044 fuel pump
kaaz 2 way lsd
not much mods to the 26 tho
slit dumps
power fc
sump modded for rwd
Lighten Flywheel
R33 gear box
nismo short shifter
ORC single plate clutch
thanks
https://www.sau.com.au/forums/topic/205239-my-r32-gts-t/
  • Replies 69
its finally the day aye Gordon :D, i bet ya cant wait until shes ready, ill be keeping my eye on this thread closely :)
its good to see you stuck with your idea with the 26 conversion and didn't get scared off by all the people that say "its a waste of money, buy a gtr" LOL
Edited by sam5709
https://www.sau.com.au/forums/topic/205239-my-r32-gts-t/#findComment-3638581
yeah i know its just a waste of money and effort if i just gave up with my car and bought a GTR. well today not much was done cause did drive my car there and was in the sun most of the time so engine didnt really get a cool down to start stripping it to get it out, well tomorro will be bringing the engine down and start changing all the gaskets and stuff, and maybe start stripping the 20 down depends how much work i feel like doing.
https://www.sau.com.au/forums/topic/205239-my-r32-gts-t/#findComment-3638678
arghhhh was going to go to my friends to pick his car so i can take the engine there but noooooo hes not home all day, a bit annoyed but sh*t happens, well i guess i will be doing the most i can at home and will take pics as i am going
Edited by Flash89
https://www.sau.com.au/forums/topic/205239-my-r32-gts-t/#findComment-3639739
hey guys, well managed to actually get a car to take the engine over to the work shop, but spent some amount of time to get it into the back, it was a ute but had like a paddy wagon cover like thing hehe. all thanks to my big brother.
anyways some custom work was done, i started on making pods in the passenger side for three of my gauges, i have just started with the base of it. will do the rest tomorro then will start on the engine
pics i got here is engine when i got it
engine when finished painting it
engine in work shop
tomorro now will be taking the gearbox in, but i am still waiting for my clutch to arrive as it is still in transit between brisbane and perth.
https://www.sau.com.au/forums/topic/205239-my-r32-gts-t/#findComment-3641632
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
