  • Replies 69
http://www.skylinesaustralia.com/forums/up...59916_thumb.jpg
Just a question... why go to the trouble of putting nice gauges all the way over on the other side of the dash when the only time you would read them is when you were drifting around a right hand bend, at which point i would be watching the road rather than my gauges? I can't even read the numbers without blowing up the image.
I'm by no means having a dig at you for it, as I believe everyone should modify their car in what ever way makes them feel good... I just have never understood it???
I will say that I am happier to see that you didn't just get the hole saw and cut straight into the dash like some... very handy work there with the glass mate, well done.
but the thing is if you know what the gauges are (ie position) and what the needles usually sit at, all you need to do is take a quick glance, check the needle position and see how its going....
it the same with the gauges place under the head deck near the shifter - its hard to read them there aswell....
Foremost expert speaking!
well here is my piller pods i have been doing
i know i could of bought them but thought i will just make a custom one
whats yous think
also car is heading off to briffa this thurday for piping
Edited by Flash89
hey guys
car was dropped off the briffa on thursday for the IC piping and was all finished today, mick wasnt kidding when he said he will have it done by the weekend , but couldnt get a tow so car will be back to beyond for wiring tomorro yay
i guess i will find out in the next 2 weeks, cant drive hard straight away got to wear in the clutch. also i think i will have a problem with traction cause it getting into the rainy weather :) hehe
i never understood why 32's have a break duct on one side but not the other lol. oh well
It's for the stock intercooler..
Anyway, nice work Flash - always good to see another rwd 32 getting a huge power upgrade :(
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
