Just done a piston ring and was wondering what i was better off doing. i have sourced out a second hand engine for $1500 + 500 to put the thing in. Would that be better than rebuilding because i know rebuilds are very expensive and i also have the drama if there is a damaged block or valves, just a waste of time i think. correct me if im wrong.
Also can anyone tell me of there experences and how they got out of it. Where they went how much?. How much would a full rebuild with forgies,bored and balanced be.
https://www.sau.com.au/forums/topic/205260-engine-rebuild-or-second-hand-motor/
Id say do a rebuild.
You have the option of getting all the extras ie forgies etc etc and at the end of the day you know the engine is basically going to be new. Whereas buying secondhand... well its second hand. Guess it depends apon your budget etc too.
what comes with the second hand engine? you might be able to sell off leftovers to recoup money ie turbo/loom/head (always people wanting to go RB30DET) or was it 1500 for the bottom end only? (rip off if it is)
If you are going to get a rebuild done by someone else and do nothing yourself then you wont get any change out of 6 GRAND, now that is 3 second hand motors fitted. The other thing is the type of power you are (or planning to) make. If your car is mostly stock and going to stay that way then a rebuilt motor is going to be a waste of money. I was in the same boat about 4 years ago and went for a full rebuild with plans of a monster engine but it never happened and I sold the car with the motor in it and did not make any extra money out of it. So you have to be realistic about what you want to do in the future and use that as the basis for the new engine. I wish I had taken the cheap option as that would of given me more money to do some of the basic mods like computer and front mount and high flow instead I ended up having a car with a built motor and nothing to make it go fast.
All the best with the decisions.
Andrew
Andrew
$6000 to rebuild a motor your f**king crazy.
R33747 pm me i have a number for you to get rebuild wont cost much at all
Edited by rich flavour
1500 for a complete motor minus loom and ecu . i have an afermarket turboand power fc that ill be using so i could sell the stock turbo here for a couple of hunderd bucks. Not bad considering how much a rebuild would cost. ive spoken to my mechanics i use a both said that the better option because stuff can go wrong with a rebuilds.
Also wondering how can i tell if a motor is in good condition. Can you do a comp test when the motor is out of the car? Ive got 5 to choose from but have do i decide which is the best one?
basically - the rebuild is a better option if you can afford it, and you are planning to keep the car long term.
but the difference between rebuild and second had is literally thousands $$$ so if you can't afford it just grab the second hand one.
I've done both - second hand into the road car and rebuild the race car. the second hand motor was fine.
Um im surprised noones susgested it yet but wouldn't u atleast pull old motor out pull the head off etc and inspect engine damage before writing the old engine off im sure a new set of pistons and getting the cylinder bored, 2nd hand gtr rods etc wouldnt cost a hell of alot more then 2nd hand motor and atleast u no if u looked after the old motor ur not getting another motor which has already doen some work as opposed to rebuilt orginal motor thats been looked after. But if the motors bad needs headwork etc to repair mayaswell throw it away.
thanks just my opnion Rory
2nd hand way cheaper. rebuild takes time and money. you cant say that rebuilt motors are always more reliable then 2nd hand. whats if the bloke building the motor does fantastic work but comes in 1 morning after a hard night and stuffs something without realizing it. bang goes the motor and ur back to square 1. it has happened before. you might get a crappy 2nd hand 1 as well. just gotta check out the motor before buying it if u go 2nd hand.
hahaha thats called a 'rebuild' dude, have you actully been reading the thread?
just rebuild mine. done a big end bearing.
replaced the crankshaft, bearings, rings, conrod, cleaned head, gasket kit. all done at repco just over 2 grand.
also had the comptuter chiped by Dr Drift and my rb20 turbo now with steel wheels and inlarged.
could of got a engine for a grand, which is about what i thought it would of cost but cost double!!
seem to have a loose tappet and a noise coming from the front cam wheel cover (unrelated i know) that we cant pin point.
started removal work on xmas day and turned the key friday (8th)
JBR
Edited by johnGTS-t
does anyone know of good places in melbourne that do good cheap rebuilds?
i do them, usually only by reference, but you will have to drop the engine off to me in keysborough. i will strip and photograph your eng and only replace what is needed or i can do some killler monster engine... whatever your budget or choice. If you want refferences i can give you the number of guys whose engines ive built.
he had a fully built engine, so i'm assuming forged pistons/rods etc etc you will EASILY spend 6k if you take it to a workshop for a "tough" rebuild
pistons, bearings, headstuds, gasket kit, timing belt, water pump etc etc all those things should be done while its torn down, and when your paying for labour it adds up very quickly, or you can go cheap and replace only the broken piston but that wont be any better than a second hand engine anyway.
If your not planning on making over 400rwhp get a nice low km engine, they can do a compression test on them outside the car, and buy the one that pulls the highest and most even numbers
or take it to URAS, it seems he knows something about skylines haha jks :thanks:
Edited by R34GTFOUR
i have a mate that works at Top Torque in Nunawading. don't know how much they charge, but theres no harm in asking. they've done a few cars from Chasers Motorsports. so im guessing they're pretty good
heres the link
http://www.aussieweb.com.au/details.aspx?id=2009642
I've just re-built an RB25DET, Rings, bearings, one piston, gasket kit, timing belt, tensioner, idler, faced flywheel, relined 5 puck clutch plate, faced pressure plate & fitted new fingers, filters and oils. Just under $1500.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
