how do i stop it for coming up on my r33 cause it looks stupid 10 foot in the air?
there is a switch on ur dash on the left hand side next to the steering wheel... try using that... or listen 2 a CD...
there is no switch on the left hand side an when i put cd on it doesnt go down cause its a pioneer deck!
i have searched the forums for an answer but cant seem to find one unless i unplug the cable to the deck right?
i have a pioneer also got it 2yrs ago, every time i put a cd in the antenna comes up, the stereo that was in the car prior to the pioneer never had that problem, oh well u get used to it.
so other brands don't have this problem, just pioneer?
Edited by Hulk1010
pull the deck out and disconnect the antenna wire.
but what about when i want to listen to the radio, will the antenna still come up?
i had the same thing
i found sony ones have seperate antenna activate wire that only makes the anteanna go up when u listen to radio
pioneer only have the amp activate whichi s shared with the antenna so the antenna goes up all the time. i just disconnected it. i got good radio with the antenna down somehow?
the swtich in the picture controls the aerial height... i took my dash apart to install the white speedo kit and obviously disconnected everything... when i reconnected everything n turned the radio back on, it went (like you said) 10ft in the air... i pressed down on this switch and the aerial went down to the desired height... i dont know if the computers memory stores is height in it but everytime i turn the car back on, its at the height i set it at using that switch... btw my car is a R33 GTS-T sII... i dont know if the series 1 has this...
if you want height control and you are willing to go to a commodore wrecker. grab a antenna control module from a VP calais and then you have height control. its on a white 6pin plug in the passenger kickpanel. then you can set it to any height you wnat.
  • 1 month later...
Oh man I feel like a tool...
I bought a sorta "CarPC" kind of head unit from the States... it does DVD/CD mp3,wmv, bluetooth, with a 3.5" screen. It didn't have a dedicated antenna control wire, and overall the product seemed lacking in the basic functions and ease of use. I had a bit of a go at the manufacturer about the antenna wire, then spent a few weeks shopping around for a "standard" brand of HU.
I just received my Pioneer DEH-P600UB which does everything except the DVD part... low and behold, no antenna wire! I could shoot myself!
As "naga" said above, it seems that all or most Pioneer units don't control your electric antenna. =-/
My 10+ year old Kenwood unit in my first car did, my ancient Sanyo "CD-only" POS did, and my current 4 year old Kenwood HU does it. The two units I have just bought don't. =-[
I feel your disappointment... the antenna up all the time looks dorky.
i have a r33 1995/ series 1.5 and im pretty sure ih ave that switch, just not in that same poistion. I will check when i get home from uni and post a pic up..
I may be wrong tho. Shall see tonight.
I have a series 1, no switch. Actually i have no antenna. It's broken off. I reckon the Jap owner got the shits so hard seeing a flagpole on the boot he just got out in anger and ripped it off. Hmmm, that's what too much sake does.
I can still hear the antenna motor whir when i turn on the radio- but the deck is Japanese and has hardly any bandwidth. Plus no antenna! So i just play CD's...WTF?
Edited by R338OY
Hmm, an angry Japanese owner, are you sure you didn't rip it off and your covering it up >_<
Anyway, the switch doesn't stop the ariel going up it has two settings, a moderate sort of height, and really damn high.
As soon as I put in my Pioneer stereo it goes up, even if I'm using USB/CD et cetera, so I'm considering checking if I can pull the fuse on the ariel without any negative side effects, or just getting used to it :).
For now I've gotten used to it.
Mine doesnt have anything like that, altho my aerial isnt even connected. I know the wire is broken, but i cant hear the motor running either. I just pushed mine down so its out of site. The only time the radio has troubles picking up a signal is sometimes when i reverse into the garage, and in multistory car parks, but only sometimes! My head unit is a cheap Clarion, so I dont know if it has an aerial wire or not
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
