just thought I should mention that early model series 1 stageas cannot run an unmodified R34 PFC.
It looks like in early 98 (probably the same time they release the r34 skyline) they changed the ECU wiring in stageas.
R34 GTT PFC will not run a pre 98 stagea without modification of the pins. It starts and then stalls straight away
the guys up at Hills Motorsport are working through it now but there are significant changes required
First problem is the CAS signal is in the wrong place
Second problem if you sort that, is the knock sensors are at a different pin. this is bad.
Will post up all the differences once we've got them sorted :cheers:
https://www.sau.com.au/forums/topic/205298-r34-pfc-doesnt-run-all-s1/
  • Replies 82
so...shouldnt you just use an R33 pfc ?
keep us updated please
* better hold off on the tune of mine then
that being said, Im still thinking about piggybacking it.
boostwerks have a bloke they will call in, a nissan wiring freak they reckon, so Im confident in my own way that a solution can be found.
good luck with it
Thanks Brendan I was going to give you a shout about the differences. Mine isn't sorted out yet maybe it will be the same. They are translating wiring diagrams at the moment. Glad I didn't try this one.
well.... I plugged my R34 GTT Power Fc into my 1997 Stagea today
runs for the first 3mins reasonably steady, but gradually starts to hunt for the idle, by the 2.30min mark she is hunting from 800 down to 300, then stalls,
cant get past that 3min mark without having to reset and retry.
but definately runs.
onlly errors on the PFc hand controller is "Boost" and "Thro", boost at 0.00v (just realized now I had the boost control kit option turned on, not off, oops) and thro at 5.11V
also I never made a change to the Airflow metre setting.
might go reinstall it, and setup the settings properly, see what happens
wonder if Neo injectors have different values than non-neo rb25 injectors, ie latency difference from 0.528msec to xxxx
this wont matter to me in the long run, as I have some S15 480cc highflowed to 550cc injectors, with 1.100msec latency. that will be setup at the tuners
along with the mod to stop the engine check light
if THRO is at the ceiling value 5.11v im not surprised its staling
the FC is being told the throttle position sensor is out of scale or disconnected
ive seen my GTST THRO drop to 0.0v and peg there - the FC locks the revs really high on idle around 1600rpm and keeps it there
i would suggest looking into why THRO isnt working - the car wont work without it
http://www.skylinesaustralia.com/forums/In...es-t173670.html
is THRO the TPS signal?
if so, I believe it needs a rewire.
ie throttle motor sensor signal pin# is different on R34 GTT PowerFC vs Stagea ecu
#51 compared to Blank
whereas all other Throttle signal pins are the same #
I think what your talking about is the throttle motor, which is only on the R34 GTT, and I believe it's used by the traction control system.
If I remember correctly Andy (EGA41T) called the fix "The secret squirrel tweak", do a search for that and you should find your answer.
yup
was pretty sure that was the case
cheers Brendan
already got the diode, resistor and wire, plus the diagram of course
cool. its definately going to work
will book a day I suppose and get all the work done.
550cc deatchwerks injectors (hiflowed 480cc items)
hks heavy duty actuator
stock bov, oil, filter
powerfc + boostcontrol kit + secret squirrel trick
splitfire coilpacks + .8mm copper sparkies
(Id put most on myself, but cant be stuffed leaning over the engine; just ruins my knees = not worth it)
ok if thats the case then in SENSOR SW CHECK should have TPS and THRO
do you have both >?
