lol! I wonder what is 'normal spooling noise'? Can anybody with a S2 that is 'normal' be bothered to record the turbo sound on boost? That might give those of us who suspect something is wrong a better idea... just a thought... objviously if you have an exhaust which covers it up that might be hard
I've still got the stock system. I've just never paid attention.
I'll endeavour to 'listen out' for what is normal and try to report back here.
:whistling:
the turbo shaft should not move more than 1-2mm in and out, and less than 1mm side to side. any more than that and it is on the way out
Thanks Duncan :thumbsup: That's good news.
When I had mine apart I'm pretty sure it had less than a milimeter; will try to check again. I could feel no play side-side.
Hi all
I have a S1 until just recently all I had was a nice turbo whistle. What I had was a very loud sound something like a mettle Bering grinding away at high revs. It turned out to be the exhaust manifold. I had two broken studs and the manifold was loose. I tightened up what I could now we are back to just the turbo whistle. I am doing some work on the car the week after Easter so I will try to fix the two broken studs then.
cheers
phil
Hi all
cheers
phil
Oh, broken studs... :( good luck hope you can get the old ones out
Is an exhaust manifold gasket really $94 from Nissan??? Think I will look at aftermarket ones if I ever need one!
Edited by DaveB
Hi All
I am not looking ford to working on the broken studs but it has to be done. I am hoping that the other 10 will come out easerly (If 2 are broken the others may be close to being in the same condition hence the reason for doing the lot).
I thort that $94.oo sounded a bit dear but I got it anyway
Cheers
Phil
:P
Hey Reuben what can you hear :P ?
My turbo is pretty noisy to my ears; I can pop the bonnet and rev it a little and it sounds like a noisy fan. When it's making full boost (with the high boost mod, so it happens at ~2,250 RPM and there's less engine noise to compete with) it sounds like a pretty loud noise, bit like a jet plane taking off but not that loud. Not loud enough now for people on the side of the road to hear - I don't think - but disturbing. Dunno if it's normal... will try to record a sound clip for you all...
    • I'm not sure the diode only will give the desired result. I'd probably approach it with a couple of relays (And you still might need a diode too!). You need to be able to break the constant feed from the headlight to the orange corner globe when the indicator is flashing. Not knowing which Skyline we're talking about specifically here too (And it may not matter, but I don't know the R34 column switches) you'd likely need to rewire the stalk, so that the indicator power itself no longer runs through the stalk too, as now you need it able to trigger a relay that will break the constant supply from the headlights to the indicator, then you'll need a separate relay to trigger the indicators to come on (Replacing the internal action of the indicator stalk).
    • Weird story from me My Toyota 86 was with Commbank comprehensive but for market value (who they use to underwrite is unknown) When I munted it beyond financially viable repair in 2020, rear end smashed in to the point it bent the rear quarter and roof, they knew I paid $31k cash for it because I told them, they still paid me out $38k, as all the 2017 limited edition variants with typical Km and condition were going for between $36-41k, so they did weird math and came up with $38k I never officially mentioned any of the mods that I had done, but as they were not the cause of the crash they were not fussed at all, the insurance inspector actually asked if I wanted to replace all the mods with the OEM stuff if I still had it laying around before they took the car I still came out of it behind though, because I had probably dropped $20k in it with the suspension (bent after the prang), wheels (bent as well) and "other" mods, that the inspector asked about But still, as the market value was higher than what I initially paid, and they paid out market value To say I was surprised with the outcome would be an understatement  Weird, but true, but probably just lucky with the inspector on the day I guess  Sadly, I don't think if I munted the old NC1 MX5 I would get the same result Meh, pay to play
    • Well, the car is back, all straight and shiny, for how long for is anyone's guess  After picking it up we went for a bit of a drive, Jebus I really enjoy driving this little thing, hopefully the weather let's us go for a nice long cruise this weekend as it will be out of my hands for at least a few days next week when it heads back into Mania on Monday It's weird, whilst I do always enjoy going for a drive, the NC makes me feel like a kid who has just got his first car, and they just want to drive wherever and whenever they can I really need to look into the MX5 Club of NSW
    • wow that is some seriously JDM original credibility there!
    • Selling hks rb25 cast manifold and waste gate.   Never going to use as don't have Rb powered car  Unknown condition of waste gate diaphragm  $900 Pick up only Ipswich Qld
