does anyone know anything about Mitsubishi Legnum vr4's, Galant VR-4's. or Toyota Chaser Tourer's?
my dads looking at geting an import but i cant give him any advice about any of these cars.
dont want to get one and have it brake down straight away.
here are some some he was looking at
http://www.j-spec.com.au/list/index.php?ID=12057
http://www.j-spec.com.au/list/index.php?ID=12032
http://www.j-spec.com.au/list/index.php?ID=12016
https://www.sau.com.au/forums/topic/205375-need-info-about-some-imports/
I don't know much about the Chaser's, they're a rare car over here, especially if they're a manual. Engine and driveline in them have a fairly good reputation but I've no idea how it is as a driving package.
The Galant and Legnum VR4's are rockets, even in stock form they're doing around the high 12 to 13sec mark 1/4 mile on road tyres, which is none too shabby really!
Pretty much everything you'd find in a Evo models of the same era ended up in those cars but with a different engine, of which is a very powerful and compact piece of work. I've said it before that they are not the most enjoyable engines to work on, but like someone else pointed out, not a lot of the really modern cars are very much fun to fiddle with! To the best of my knowledge neither have anything particually 'grenade like' about them
I would go for the Toyota Chaser Tourer V (JZX-100)
Great performance sedan, very clean looking, and inconspicuous to those not in the know in regards to the less common imports.
I personally think it would be highly enjoyable lining up next to a few falcon's/commodore's. :(
I've seen a couple on the roads (not many though), with subtle exterior mods, and they look very neat, whilst not screaming for attention.... ,although driving past one with a 3inch exhaust, and an FMIC neatly hidden behind the front bar definatly got my attention. :teehee:
The VR-4's are definately great cars, with the Legnum being a stationwagon version rather than a sedan like that of the Galant, so depends on what exactly your Dad is looking for.
IMO, the Chaser is a definate winner.
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
