Originally posted by Initiate
Agree on the waste of a nice car, but shouldn't the emphasis here be on the poor sod who probably isn't alive anymore, or at the very least very seriously injured???
Amen brother!
screw the car, i feel sorry for the ocupants.
https://www.sau.com.au/forums/topic/2054-funeral/#findComment-38065
Originally posted by carlo
Thats what happens when you lose control of your car. If your not in control then your not going to have much luck.
The 2nd photo is a good example why we have to have intrusion bars on our imports. Why they dont have them in japan is beyond me.
R33's and R34's have intrusion bars as standard.
It's a cold hard fact,,,if you race hard on the street that sort of crash is always a possabilty....The 1st cars not that bad,,,,the rear end has absorbed most of the impact,,,the o/s/r 1/4 has done its job very well. As for the 2nd pic ,,,well hope no-one was in the passenger seat,,,,. I see this crap on a regular basis,,,,We actually drive a VERY safe cars......Sick person I am,,,,,can I have the Wheels off the 2nd car,,,they look okay.
Neil.
https://www.sau.com.au/forums/topic/2054-funeral/#findComment-38883
Side intrusion bars would (and did) do sweet FA on the car that poled the passenger door!
Just thought I would make mention of the two pictures I contributed to wreckedexotics.com :)
http://www.wreckedexotics.com/cars3/new/35..._071902_04.html
http://www.wreckedexotics.com/cars3/new/35..._071902_03.html
https://www.sau.com.au/forums/topic/2054-funeral/#findComment-38954
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
