Hey guys,
For those you who owns a R33 Series 2 with the stock front bar,
I'm pretty sure you get an eyesore from looking at the front amber indicator lens.
Here's a little tutorial I've made where I took out the amber lens and replaced them with some custom plastic lens.
First of all, you'll need to take out the foglight/indicator assembly out of the front bar.
If you have a FMIC then you'll probably have to take off the front bar or headlight (whichever one's easier)
If you have just a stock SMIC then it's pretty simple to take out,
There are 2 10mm bolts on the inside of each foglight/indicator assembly,
One is located near the middle, the other is close to the edge where the piping would be if you had a FMIC.
After you took out these 2 bolts, there is clip that holds the foglight/indicator assembly to the front bar,
Push down on the clip to pull the foglight/indicator assembly out,
Then disconnect the foglight/indicator connector from the car to take out the foglight/indicator assembly.
Secondly you'll need to remove the amber indicator lens from the foglight/indicator assembly.
There are six screws holding the front cover of the foglight/indicator assembly, unscrew them and you'll be able to take the cover out.
Then heat the foglight/indicator assembly in the oven at 160-180 degrees for 5 minutes to melt the glue that's holding the lens in.
Use a screwdriver and gradually anchered the lens out, do be careful not to get the glue onto the indicator slot's reflector.
If the glue hasn't melted sufficiently, put the foglight/indicator assembly back in the oven for another 2-3 minutes and try again.
You can try breaking the lens if you don't intend to use it anymore, but there could still be some little amber fragments glued on.
Thirdly is to fabricate the lens, I bought my plastic lens material from The Plastic Centre.
They're located at 192 Princes Highway Arncliffe NSW, there's lots to choose from, smoked, opague, frost ... etc.
Costed me around $20 which isn't bad, but that's the minimum you'll have to spend anyway.
Try to get the lens between 4mm-6mm in thickness, any thicker and it won't fit into the assembly.
Next thing to do is cut the material down to a size to fit into the indicator slot.
Get a piece of paper and trace the outer edge of the amber indicator lens that you've just took out.
Cut out the shape and draw it on the lens material using a marker/highlighter (preferrably light in colour).
then using that thermo heating pen, melt the plastic material into that shape.
I'd advice you get a 50W+ thermo heating pen, as mine was I think 30W and it's a bit slow to melt the material.
Remove excess plastic with snippers or your fingers when it's still warm and file it smooth.
Finally after the lens are made and fits well, just use some strong insulated black tape to hold the lens onto the foglight/indicator assembly.
Seal it and make sure no water can leak into the lens.
Then it's simply screwing the front cover on and bolting the foglight/indicator assembly back onto the front bar.
The foglight lens still looks different to the indicator lens,
That's because the indicator slot's reflector is not as shiny/reflective as the folglight slot's reflector
So underneath you'll find some pics with a few hints of where everything is.
If you have any questions then bugger off and figure out for yourself :thanks:
looks awesome. I always considered if i owned an r33 buying two of the driving lamps and placing them on the outside and wiring them as the indicators with orange bulbs. Dunno if they fit the outside hole though.
This looks great!
  • 3 months later...
Maybe you're looking for something like this. :P;):P
Of course, anything is possible if you put you're mind to it.
Good luck
Shaft
This looks great!
Edited by shaft no 1
That looks awesome
Might have to give this a try :P
Also you got a pic of when the light is on?
Just wanna see what it would look like when you turn on the indicators
ta
Edit: I think i spotted you on sat night?? did you go thru the m5?
Edited by siddr20
nah think again, I was on the M5 just afternoon on saturday
anyway here's a few pics I just took from the garage.
it's not as bright as it looks, but you get the picture.
Edited by POLICE
  • 4 years later...
i know its been a long time since this thread has been posted in but thought id post some pics of my 33 with this done. All up cost about $5 for the platic lenses and $14 for the amber globe paint. Took around an hour and its definatly worth the time and money!!! No more crappy orange indictors :)
    • I don't like "actual computers" for in car use. They take time to boot up, have OS annoyances, and so on. Arduinos etc are ready to go a few seconds after power on, don't mind being agressively powere cycled, because everything is non-volatile, don't mind being shaken and stirred.
    • As Fred would tell us, it's all about interpreting the rules. It's not a water sprayer, it's a water mister... But everything else you've said, 100%! Even a raspberry Pi would be great, use HDMI out for a display, and add a raspberry Pi CANBus hat to read values out from the ECU.
    • Being a race car, and being in the era of the Arduino, one would think it would take little effort to build a controller to do the spraying based on a real physical measurment. Waaaaay back in the dim dark AS days, JE "designed" (as in, he had help) a microcontroller based intercooler spray system. It watched the difference between a temp sensor stuck on the core and one in the free air in front of the cooler, and if the temperature difference exceeded a (settable) threshold, it would activate the sprays. Thus, it only ran water when there was an actual need for water. If you stop to think about the actual physical things that are going on in that stack of coolers, there's probably at least a couple of triggering conditions one could come up with, and one could probably even run one pump with more than one solenoid valve, to allow water to be placed where it is needed, or at all points at once (if it is needed at all points). We're in the age of science baby. But.... I suspect that intercooler water sprays are on the forbidden list in most circuit classes, no? So only good for Targa type stuff?
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
