Ok for sale is my 93 R33 turbo skyline coupe.
Bad points
its an auto,
has a small crack in passengers front window.
Good points
Gear box just fully serviced
3 point imboliser fitted
Tinted windows
94000kms
Rego till June
Serviced every 5000-7000 kms
Price $7000
Mechanically A1
Located in Coffs Harbour NSW
Contact phone number 0412179033
https://www.sau.com.au/forums/topic/205468-fs-turbo-r33-coupe-7000/
is this an non-turbo that has a turbo engine?? or has the engine just been turboed??
as it has blue badges and 4 stud rims so must have been originally na.
ummm.. the second picture, where the car looks like its BENT!
it has 4 stud wheels.
and no 4 piston calipers.
so is it a non turbo car that has then had a turbo RB25det put in to it or the stock RB25DE that has been turbo charged?
pics of engine bay?
hey price drop to $6500
Have reciepts for the new engine and gearbox which totally $2600 plus the $1200 to get it all mechanically put it in.
So going cheap.
Only reason for sale is my psyhco ex is chasing down money quick so need it gone quickly
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
