hey guys..
the previous owner decided to take the steering wheel off and put a boss kit, only to realise theres a different one for air bagged equiped cars (?)
anywayz he didnt end up doing it and just put the stock one back, which is a good idea lol but he said ever since his put it back, the horn doesnt work, and the airbag light is always on in the dash.
i think maybe his done somthing wrong with the wiring, so i wanna give it ago and try sort it out this afternoon.
any advice? whats the best way to remove it? also is there a seperate clip that connects to the horn and a different one for the airbag...obviously his mis matched the cables.
thanks
Haha, I did this just last night :(
apparently, once you disconnect the airbag, you need to reset the abs or computer or some junk*... try that first... I'm up to having the airbag light on also, haven't tested the horns...
As for getting it off, you are going to need a special piece of equipment... You need a T10 anti tamper torx screw... Took me ages to find one after asking mates and a few shops I go to...
Hopefully when I change the battery and reset the ecu, it will fix the error code comping up for the airbag...
*This is only if you have power on... I was listening to the radio while doing it, not super smart now that I think about it...
Well that's the whole reason I was going to swap mine... the weight at the top had broken off and was jiggling around and sometimes connecting the horn and setting it off...
I pissed that weight off, but I don't know how much fun it will be driving an even more uneven steering wheel...
Where abouts in Sydney are you?
the horn isnt my main conern right now, but while the wheel is off might aswell check that and airbag connections
from sutherland shire
is there an air bag reset that can be done, before i start pulling things apart?
Yeah there sorta is, but I don't know what it is exactly... it's some code, like you have to turn your key to ACC, then press the door button in the door sill 10 times in 10 seconds or something like that...
Do a search, it's probably here somewhere :(
THIS IS HOW TO RESET THE AIRBAG COMPUTER
First you have to put the system into the diagnostic mode. Here's how to do this:
From User Mode To Diagnosis Mode:
Diagnosis Mode activates only when a malfunction is detected, by pressing the driver's door switch at least 5 times within 7 seconds after turning the ignition "ON". SRS will not enter Diagnosis Mode if no malfunction is detected.
From Diagnosis Mode to User Mode:
After a malfunction is repaired, switch the ignition "OFF" for at least 1 second , then back "ON". Diagnosis Mode returns to User Mode. If switching Diagnosis Mode to User Mode is required while malfunction is being detected, switch the ignition "OFF", then back "ON" and press the driver's door switch at least 5 times within 7 seconds.
After a malfunction is repaired, return to User Mode from Diagnosis Mode by switching the ignition "OFF" for at least 1 second, then back "ON". At that time, the problem code is cleared
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
