since setting up everthing i needed manifold/turbo wise my next step was to choose a good wastegate.
i was wondering out of the pack turbosmart seem to be the cheapest (due to it being a aust product maybe?) but i was wondering out of all of em tial, hks, turbosmart ect ect, are there really any differences? do they make different sounds? (yes i plan to atmo) and how do screamer pipes affect them? sizes available and good performance?
i believe i would be oping for a 44mm but feel free to correct me if im wrong.
the setup will be a 25/30 rebuild with a gt3540
cheers
Edited by R34NRG
https://www.sau.com.au/forums/topic/205485-ext-wastegates/
I was advised to get TiAl and only TiAl.
Got a 44mm TiAl gate to go on my 25/30 with the same turbo :/
Edit: got my gate off a guy on ebay from the US for a reasonable price.
Edited by bubba
https://www.sau.com.au/forums/topic/205485-ext-wastegates/#findComment-3637849
Part of your decision will come down to available space to fit the gate. The Tial gates are generally of a more compact design than the turbosmart items. The turbosmart pro-gate is 48mm and is a sizeable gate compared to the Tial 44.
Your getting a 6Boost mani aren't you? I know Kyle recommends the Tials due to their compact design which generally allows the gate to be mounted straight off the manifold for better boost control rather than having a 90 degree bend off the manifold to the gate.
Edited by juggernaut1
https://www.sau.com.au/forums/topic/205485-ext-wastegates/#findComment-3637941
A wastegate is a wastegate if you ask me
Different brands are different sizes, thats about all there is to it.
I ran a Turbosmart 45mm gate (obsolete to the 48mm) without issue, and i know plenty of other people that use Tial, Turbosmart, HKS without any issues.
https://www.sau.com.au/forums/topic/205485-ext-wastegates/#findComment-3637960
i still cant get my head around what size to buy?
I have a 38mm TIAL I got cheap off the forum to run with my 3540 powered RB30DET but am unsure if it will be a suitable size for my application
https://www.sau.com.au/forums/topic/205485-ext-wastegates/#findComment-3638063
yeah I have read that a couple of times now, still dont completely understand it but im getting there.
what I would like to know is how having a gate that is too small going to effect performance?
From what i can see it will cause over boosting as there is physically too much exhaust gas to fit through the small gate
https://www.sau.com.au/forums/topic/205485-ext-wastegates/#findComment-3638173
I dont really care I just need to get the car to the exhaust shop then to the tuner to slap a run in tune in it
once the motor is run in and the wallet has had some time to recover I will buy what ever sized gate i need to run ~20psi at this stage I just need it running
https://www.sau.com.au/forums/topic/205485-ext-wastegates/#findComment-3638215
38 way too small, im using a 47mm on our car and it is marginal.
if you on a budget i would only ever consider tial, ive used turbsmart and they fine but are just way too bulky ..
Best bet if you r budget is a bit bigger to use brands like hks, sard (my favorite) greddy etc as they are nice and compact and flow extremely well... i used a Blitz D47D on cats car as i wanted a small gate (close too being to small as possible to aid rapid boost control) and the D47D has twin screamers and flows extremely well.
https://www.sau.com.au/forums/topic/205485-ext-wastegates/#findComment-3638233
Its strange how they sound so different. Two cars i have been in that ran a Turbosmart Gate both sounded similar, whilst the Greddy Type R does seem to have a distinctive sound as well. But that could have a lot to do with manifold design as well
yeah, even though it isnt a consideration the turbosmart gates seem to sound like ass, i remember swapping out my SARD gate (damaged diaphragm for a turbosmart one way back for some testing on the series 6 and well yeah... regret is one word for it. They do however work well for their cost and we use a few (more 38mm than 44's) as many cannot afford anything else but whenever possible i try to swing em across to TIAL as they are easier to live with size wise.
https://www.sau.com.au/forums/topic/205485-ext-wastegates/#findComment-3638548
I used the formula for getting my wg size and it was 40mm, tial had one listed, but I couldn't find a business that would supply one. Couldn't find another company that made one that size. I eventually found a second hand HKS 40mm with a creased diaphragm for $200 and then fixed it up [anodised, high temp coated and new diaphragm etc], seems to work well. I settled on an 18psi spring, but I've got a 14 as well and might try it one day.
You'll have to use the formula and see what size, then decide what boost you want it to work at and the spring rate etc. Its the only way to get it right.
https://www.sau.com.au/forums/topic/205485-ext-wastegates/#findComment-3638837
The turbosmart gate (45mm) that i had, was the best sounding external i've heard to date... and Troy yours would be second on the list without a doubt.
RB20 and your manifold combo has a different sound to it.
More to do with manifold and the way the screamer is (size, angle of cut) than anything else IMO.
https://www.sau.com.au/forums/topic/205485-ext-wastegates/#findComment-3638856
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
