I have the following aviable
1 x R31 Turbo (with lines & bolts) 24,000km's
1 x R32 ECCS Plenium
1 x R33 Standard Exhaust manifold
1 x R33 O2 sensor 7,000km's
1 x R33 Dump pipe (half a foot long u know the one)
and theres a heap of other crap in the box i dont want
like heat shields and mounting brackets for the bits and
pieces im selling.
Want to sell to Brisbane person as mail would be expensive
for a box so large and very heavy.
Need $200 firm for the whole box...
https://www.sau.com.au/forums/topic/20550-r313233-bits/
The R31 turbo bolts onto the r33 exhaust manifold all of the exhaust manifolds are the same R31,32,33.....
Im selling the turbo separate for $150 now....
150 is last offer and is firm sale.....
The rest of the junk make an offer
Note: the turbo comes with the oil & water lines
Call me on 0433 123 024
https://www.sau.com.au/forums/topic/20550-r313233-bits/#findComment-441491
  • 3 weeks later...
  • 4 weeks later...
hey, how much r lookin for in rgrds to the std maniflold and R31 turbo?
how many k's on the r31 turbo? bolt straight on to the manifold?
what is the difference btwn that and a r33 one? power wise? design wise?
thanks
https://www.sau.com.au/forums/topic/20550-r313233-bits/#findComment-522425
... ok for the last time...
I dont check this forum....
Phone me on 0433 123 024
No plenium pipe over cam cover
02 sensor is worth more than 10 bucks
r31 turbo is not a good choice for an r33....
(thats why i pulled it off and put an r33 one on)
please ph me....
https://www.sau.com.au/forums/topic/20550-r313233-bits/#findComment-525094
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
