I managed to stuff my RB20 at power cruise, pretty sure a bearing has gone so the lot is for sale.
The following items were bought but not yet fitted to the motor.
Trust TD06-20G - Good condition $1200
Set of 6 GTR injectors, $300 o.n.o. SOLD
GTR resistor pack, $150.. Only turned up in the mail this afternoon, that's what I paid for it so would like to make it back. SOLD
I have a near complete RB20DET with what I'm guessing has spun a bearing. The motor is still in the car and still runs (as it only went yesterday) and is fitted with the following aftermarket parts.
VG30DET turbo (fitted with r32 wastegate actuator, spring is at 12psi) SOLD
Split pipe dump modified into screamer pipe
Also selling RB20 Gearbox.
Price on the above will be worked out upon what the buyer wants included.
Please don't hesitate to contact me with any questions.
Thanks, Jayson
[edit 18/2] Also have 6 Standard R32 GTS-T rims painted black, $50 a wheel.
RB20DET gearbox $400 or best offer.
TD06-20G still here aswell.
R32 GTS-t tail shaft make an offer.
Have intercooler pipes here to suit generic 300x600 front mount.
Stock RB20DET ecu. $150 OR BEST OFFER
RB20 Alternator, reco'd around two months ago $100
Engine at the moment still has full intake side attatched minus alternator, exhaust side missing turbo and lines, Still have stock manifold. Would prefer to not have to pull the engine apart, am willing to take exhaust manifold off but prefer to keep intake side complete. Make an offer will let the lot go cheap, pull apart whiz a new rod and bearing in and you'd have your self a good RB20 for f**k all cash.
My number is 0409869892 if you want to reach me urgently.
Have plenty more bits laying around to suit RB20 so whiz me a PM if you're after anything in specific.
Jayson
Edited by Jays_5000
Gear box is feeling a little tired, apparently its got a short shift kit and all with it. When its warm it will some times knock when your in neutural and foots off the clutch so don't know if it's the input shaft or just a throw out bearing... All gears work and still shifts quite well, just gets a bit noisy. I don't need it anymore so if your keen PM me an offer.
I'll check the turbo for you mate.
Jayson
No worries.
Type: TD06-20G
Serial no: 970929005
Part no: blank
MFD n: 49179-01180
Sorry mate, not the L2 you're after but it is the newer version of the plain 20G (blue tag), if your interested send me a PM and we'll be able to discuss it further :banana:
Jayson
Thanks for the prompt response Jayson. It seems its the same turbo as i already have. For any RB20 owners out there, you should serisouly consider it as its about as big as you can go on a std Rb20 and still have reasonaly responsive engine and be able to make 240-260rwkws, all on a std motor. Great turbo for a 2L, they do have a big turbo feel to them when you drive the car :cheers:
Cheers mate, they are definatly a good turbo on almost any engine.. 20G's love SR20's even more than RB20's. I know of 1 or 2 180's fitted with them down this way that would be pushing close to 300kw with the right supporting mods. IDEAL!
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
