Hi all
I have recently installed a catch-can to my 26 and have since had all sorts of weird hesitation / missfiring / random stalling.
Heres how I have it plummed up (From left to right)
Pipe from plenum area to drivers side breather: Left in place
Both left and Right side breathers are now piped into catch can
Pipe from passanger side cam breather to turbo intake pipes: Blocked
Now from what I know, the pipe from the plenum side of things only opens on vacume, on boost it closes up, which is consistent with my problems only happening off boost. What I think is happening is that air is being sucked through the catch can into the intake manifold off boost and hence not going through the AFM's, causing my missfire etc issues? Most of the time, if the car missfires or gives flat spots, clutch in and rev's will fix it, or getting some boost into it will fix it.
What I want to know is, if I put a 3rd line from the top of my catch can back into my intake piping, where the old pipe used to go, will this fix the issue and will the catch can still work?
Thanks in advance
Ian
PS I have dodgy paint diagriams of what I mean, let me know if you need them...
https://www.sau.com.au/forums/topic/205534-rb26-catch-can-piping/
Is the can sealed, or does it vent to atmosphere?
If it is sealed (which it should be, so it is an oil / air separator), I suggest you plumb it as:
Rocker vents -> catch can 'in', then catch can 'out' -> turbo intake
yes its because you have a breather on your catch can causing it to suck through that and run lean. Either pull out the pvc valve and block it off and have it a full venting to atmosphere setup which is illegal, or plumb the breather back into the inlet piping before the turbo.
The can is empty however, theres nothing in there. Will it still work?
Try stuffing some steel wool in the can. It will act as a "seed" for the oil vapour to condense around. After all, the purpose of the can is to remove oil vapour from the air.
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
