hi all, i still have these items left over from the sale, the items i have sold have been removed. Some new items have been added, in particular i have again here quickshifts for ecr33's and now HCR32's
APEXI POWER FC'S FOR THE FOLLOWING CARS:
BNR34 AP ENGINEERING VERSION WITH COMMANDER $1480 INCLUDING COD TO ANYWHERE IN OZ
BNR32/BCNR33 POWER FC UNIT ONLY $1280 INCLUDING COD TO ANYWHERE IN OZ
S14 SERIES 2 (S14A) POWER FC UNIT ONLY $1180 INCLUDING COD TO ANYWHERE IN OZ
RPS13 180SX 94-96 SR20DET TURBO MANUAL POWER FC UNIT ONLY $1180 INCLUDING COD TO ANYWHERE IN OZ
S13/180SX CA18DET MANUAL AP ENGINEERING POWER FC UNIT ONLY $1180 INCLUDING COD TO ANYWHERE IN OZ
ALL UNITS ARE USED AND PRICING IS FIRM. PICS CAN BE VIEWED HEREPOWER FC PICS
C'S QUICKSHIFTS SHORTENS THE GEARSTICK THROW BY UP TO 30% AS COMPARED TO 10% FOR THE NISMO QUICKSHIFT KIT. THESE KITS ARE BRAND NEW AND COME WITH INSTRUCTIONS FOR THE FOLLOWING CARS.
HCR32
HNR32
BNR32
BCNR33
ECR33
ER34
S13
S14
S15
GC8 EARLY MODEL
GC8 LATE MODEL
ALL QUICKSHIFTS ARE $370EACH FIRM BUYER PAYS ALL POSTAGE
IF IN BRISBANE I CAN ORGANISE INSTALLATION FOR YOU.
I HAVE NO PICTURES OF THE QUICKSHIFTS AS YET.
NO WHINGING ON THIS THREAD PLEASE. YOU CAN BUY CHEAPER ELSEWHERE? COOOOOOL! BUT I REALLY DONT WANT TO KNOW! PLEASE CONTACT ME BY PHONE ONLY 0417755890. NO SMS'S, NO PM's OR REPLIES TO THIS THREAD. PLEASE JUST EMAIL ON [email protected] or CALL!
https://www.sau.com.au/forums/topic/20555-apexi-power-fcs-and-cs-quickshifts/
  • Replies 103
Hey dude - no hassels from me - if its a personal post, its all good. :D
Will you seperate the boost control thingy from the power fc? I want to get one.
also, i will take a quickshift for my GTR (R33) - can you pm me details of postage costs etc?
Christian
hmmm.... its a bit hard to say, where are you all? i know that the cost of the cod service is $8 plus postage costs to wherever. i would say that each kit weighs approx 1.5kgs. shouldnt be more than $20-25 all up. vendetta, did you want one or are you enquiring only? please tell me because i will put one aside now!
If the diff between the PFC ser 1 and 2 is just the air flow voltage (AFM input?!?) then it shouldn't matter to you anyway brett as you have a Z32 and you would change it to recognise that before you start tuning...
Just a thought.
Adrian
not too bad if you know what you are doing. should take about 30 mins to install. instructions are pretty self explanitory, however a little spooky the first time round.
Are quick shift kits harder on the synchro's? cos i think my synchro's might be a little worn, and don't want to stuff them up any more! Some times i miss a gear when shifting into 3rd and 4th.
Otherwise a good price and i'll check the bank account!
Cheers,
Andrew
GiJOr33 im not too sure. i have heard that before though. short shift kits should minimise gear missing though as they make each shift more definite.
PRANK HAS BOUGHT A QUICKSHIFT KIT SENDING IT TO HIM TOMORROW.
HERE IS WHAT I HAVE LEFT OF THE C'S
HNR32,BNR32,BCNR32 KITS 2LEFT
S14 1LEFT
S15 1LEFT
ECR33 3 LEFT
GC8 EARLY 2 LEFT
GC8 LATE 2 LEFT
sidewaymambo thanks for that. it does say something in japanese though. i cant quite make out what it says though. when it was bought, the guy said, only for series one so i guess i have to go by that. does someone know for sure?
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
