warrick, if you get one, i will help you with it ok?
I HOPE ALL OF YOU ENJOY YOUR STICKS AS I DO MINE! CORNY EH? :bahaha:
  • Replies 103
ABM,spoke to my son & he's decided to wait a while on the shifter.doesnt get his licence back for a few weeks yet so is more interested in getting the pwerfc with hand controller & boost unit.
thanks for your help though & kind offer.
cheers
warrick
xxe-r32 going by the apexi catalogue, apexi dont have a standard power fc for the hcr32. they do however make an AP ENGINEERING VERSION. it is however a quite a bit dearer. if interested, pm me. i will see what i can do.
TODAY I SENT:
GIJOR33's C'S quickshift (mate i sent it express you should have it tomorrow)
GRIM's quickshift sent COD
B-MAN's ECR33 sent COD
I HAVE ONE ECR33 STICK LEFT
DJ its yours! Pm me your details and i will get it off to you today!
cheers mate! check your email mate. sent you my details.
chris
Well i got mine in today, and it works a treat... pretty easy to install. About 45min if take your time and you have the tools.
Makes the gearbox feel much sharper... i haven't actually taken it for a good drive, but i will tonight!!!
Thanks again Chris
Andrew
anyone got a link to how to install it was quoted $50 for the install... do you need to jack the carf up much as my jack from marlows doesnt seem to lift the wheels of the ground its weird.... it lifts it just enough to manage an oil change... but yer how can i fit this myself ?
mate... no jacking required. It came with an instruction booklet but it's in japanese... the pictures gave enough info on how to remove the old gear stick and put the new one in. I wouldn't pay $50 to install it, too easy to do. Just take the gearstick boot/plastic bit off, undo the screws and then follow the pictures.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
