Hi,
I have a Stock R34 GT-R and I put 20L of Caltex Vortex Premium by accident (which has a octane rating of 95) when I should have filled with Vortex Premium 98. This happened because there was no Shell V-Power left at the Shell servo so I decided to use Caltex for the first time and I thought Vortex Premuim was their 98 octane rating fuel.
So my question is this, do I have to empty the fuel tank of all the current fuel ASAP to avoid damage or can I get away with using this fuel (not driving hard) until it runs out and then fill up with the 98 octane rating fuel.
Thanks,
Glen
https://www.sau.com.au/forums/topic/205557-fuel-for-r34-gt-r/
with the std ecu it has maps based on 98 RON fuel
now that the user has put in penis fuel (95 ron) the timing will be too advanced so it will combust without spark - detonate / knock
this in turn will tell the ECU its knocking (assuming stock ecu) and the ECU will drop the low octane map
its still bad for the engine and i wouldnt load it up on purpose with penis fuel in it
the stock ECU has no idea (or any ecu for that matter) what octane fuel is being used
all it does is watch the knock sensors for detonation, once it seems certain levels of detonation
it assumes penis fuel is in use and drops back to low octane maps, which basically have retarded timing on them
this makes the car not detonate as the timing is very relaxed and makes the car doughy and flat
yes so in summary
your options now that you have put penis fuel in the tank
1) drain the tank and put high octane in it
2) baby it around and then put high octane in once empty
3) use octane booster and baby it around a little - i would still avoid full loading it up
it will never detonate on light cruise / crusing at 100kmh in 5th or 6th
if its going to detonate with penis fuel, it will be when its ramping on boost or on full load
this is because the engine is under load, and has much more aggressive timing
I wouldn't use octane boost .. I'd rather not have that in my motor after seeing the dirty stains it left through my last GTR's head. Maybe its just cosmetic but even so.
The 34 GTR stock ECU will probably pull timing on you even when you are driving around normally. When I had even a slightly bad batch of 98 in my 34 it would pull timing quickly after driving for a little while and would leave it retarded until you switched the car off and back on. This happened more than once so i correlated the occasions to a particular servo and avoided that from then on.
Don't load it up and fill the tank with better fuel when you can next.
if u want to use octane booster...why not use snake oil, it will have better effects :P
http://au.youtube.com/watch?v=2jbcCr2ll3c
octane boosters do shit all. put that money into an extra 5ltrs of 98 :)
I dont know what you guys are talkin' bout. has anyone actually done it and had problems???? I assume it would if you are running a massive setup, but for basically stock applications it is fine. I have done it to trial different things to my car (I didn't drive it any different - still flogging the guts thru it) and it did nothing... Think... Its 3 octane different out of 95-98.
Don't be worried mate, if you want to be careful, just don't flog it too much. :(
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
