hey im kyle and going on my P's. i was wondering to find out some info from real skyline inthusists that will know some info from experience. i was currently looking at buying a r32 GTS-T but finding out it is quiet hard and not so cheap on getting the turbo disconnected. so i was wondering wat would be a good option thats under 200kw and r33???? im just trying to find out as much as possible so i can nail it down to one skyline to do some homework on. if ne ideas plz get bak to me would really appreciate it.
murf
https://www.sau.com.au/forums/topic/205569-finding-out-some-info/
what do you mean by getting the turbo disconnected? are you after a non-turbo r32 or r33?
ohh i wouldnt mind a GTS-T r32 if possible but they are turbo. but defintaly without a turbo for either skyline
can get both r32 and r33 skylines in a non-turbo version, just hunt round
yeh i have been looking recently and found a 1993 r33 gts-t series 1 and it was a non turbo. so u can get r32 gtst in non turbo i never realised that i thought it was stock fitted with all of them, my mistake then. do you recommend any distinctive sites to look at???
i am a p plater driving a non turbo r33 1997 series 2
still goes very very hard
ive kept up with turbo skylines till about 80/90ks then once i hit 3rd gear they just thrash me
but its still a very very quick car and a lot more fun to drive then a commo
how much did that end up costing you???? i havent seen a serious 2 non turbo yet well i havent come across one on the net yet. how many kw is it????
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
