Well the time came to cross grade to more of a family car a station wagon in fact (Mitsubishi Legnum VR4 :P), so the other family car has to go. If you want a skyline or know someone who does then call me on 0417 762 104. I do not reside on these forums much anymore, so best to call the mobile.
Location - Brisbane
Details;
Price Update! Now $11,000
1994 gtst sedan
Silver
159,000 kms
SAFC II
3 inch exhaust (Trust)
3 inch dump pipe (CES Racing)
Front Mount Intercooler (450x300x75)
Tomei Pon Cams - stage 1
Front Strut Brace
Pod Filter (K&N)
Cold air partition
HKS Speed cut
Heavy duty clutch (Excedy)
Alpine Amp and 10inch sub
Sony 10 stack CD player
Window Tinting
187rwkw
14.0sec quarter mile
Was a family car mostly driven by my wife. Very reluctant sale. I would keep both if we could afford to. Solid car that didn't miss a beat.
Edited by Squizz
update
https://www.sau.com.au/forums/topic/205579-fs-1994-skyline-sedan-gtst/
http://www.skylinesaustralia.com/forums/in...t&p=3696622
If you can better that asking price by ALOT, then I'll consider looking at your car.
I am looking for a skyline, and I am looking to pay as little as possible.
The car in the link above is in very good condition and looking to sell for about $10K.
do you want to be in the game to receive the dollars?
  • 1 month later...
  • 3 weeks later...
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
