Hi all, is this normaly for a r32 rb20det to drink so much fuel.. i put 35L and only got 200km out of it and did not thrash it much and its got a tacho for air/fuel mix and it always goes to rich when i put my foot down.
***mods***
-turbo off R33
-mines ecu
-front mount
-3" turbo back exhaust
-boost on 10
-BOV
thanks for any help, please let me know if its normaly to be wasting that much fuel cause of the mods it has.. or is it bad??
Cheers
https://www.sau.com.au/forums/topic/205608-r32-is-this-bad-or-normaly-fuel/
AFR guages are useless....just for looks, dont really serve a purpose as when you put your foot down the ecu goes into closed loop mode (i.e. does not use the 02 sensor to figure out the rite AFR it just uses its Air flow meter reading and calculates exactly how much fuel it needs). The 02 sensor is for lite throttle tuning for the ecu. Im assuming its hooked up to the 02 sensor like every other one iv seen.
Turbo motors are tuned this way (when you put ur foot down) in order to keep detonation down. Turbo motors are more prone to detonation than N/A engines and hence adding more fuel reduces the amount of detonation. Hence when you put your down the AFR guage goes straight to rich.
As for you economy...i get anywhere from 400km-450km from a tank (60L). So from 35L thats about rite. I wouldnt be complaining.
put it on the dyno and see what afr its really pushing (my bet in the 10's despite the "mines ecu"), and those gauges are as useful as tits on a bull (unless its a proper wideband)
get it tuned properly, you'll notice a massive difference in ecomomy and power
It actually goes into OPEN loop mode when you put your foot down. CLOSED loop is at idle or cruise (vacuum) and uses the O2 sensor output to regulate fuel input.
I also get similar consumption as you.
Edited by bubba
I run wideband, and the engine stays closed loop (14.7:1) even on light boost. So - shouldn't go straight to rich.
I also get ~ 10lt/100km despite caning it, but I am running a 3.7:1 diff and the car only weighs 1090kg.
Sorry my bad...shud have referenced my engineering textbooks for that one (i struggle to remember the course after i pass it!) haha...indeed it goes to open loop when you put your foot down, i.e. it doesnt use the 02 sensor to regulate the fuel requirements....but when on light throttle it goes into closed loop mode.
Im not talking as in the second u put ur foot down, but as soon as boost and revs begin to wind up a bit (4000RPM +) it will wind out to rich...
Ok thanks mate, its my first turbo car so i dont know much about them but i dont mind if its alco on fuel :( cause there fun to drive and its worth it.
Thank you.
I got 495kms from 59litres of fuel in rb20det A31 the other day. Sedate driving. Rarely going past -0.2 bar vacuum on the boost gauge. So try to control your right foot and you can get even better economy.
Edited by robots
brothers rb20det r32 gets around 9-10L / 100km's. his runs rich (dyno to indicate this). so i think your economy is out the window, something is most likely wrong
I think your right.. because even my mates say my car wastes heaps of fuel even if i dont thrash it still drinks to much compared to there cars.. so i will take it to the mechanics tomorrow and see what they say.
Thanks everyone for your time.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
