Judge Bans Underbelly Tv Drama, Indefinitely
http://www.news.com.au/heraldsun/story/0,2...376-661,00.html
Is anyone else pissed off over this?
I was really looking forward to watching this, along with many other people I know.
All the hype and advertising down the drain!
Edited by abu
  • Replies 86
I herd about this on the radio this morning, I was really looking forward to this.
Never thought of it that way!
Hope someone uploads it quick, with some good picture quality.
Hey abu, where can i download from? I haven't downloaded movies or tv before.
Not sure, more than likely would be through torrents.
www.ISOhunt.com should have some episodes on there by the end of the week.
Use a program called bitcomet to download the 'torrents' from ISO hunt :P
I rekkin it should be band all over australia, Imagine If some one from your family or son had a stroy of there life on tv, You wouldnt want people all over Australia watching him or her on a Tv show. Should rember all the good times in Life not all the sad storys.
Edited by Rav
I do nightshift so downloading shows is the best way for me, plus with the good US shows you can usually get the whole season before they start here, like weeds, saw the first 2 seasons and start of the 3rd before they started airing it here, i also have every episode of dirty sexy money before it started here, also things like rides, american chopper, american hot rod and top gear are available commercial free long before they come on tv here, and then add in good shows that never come out here, one im watching at the moment is celebrity rehab (dont normaly watch reality crap but these guys are f**ked up), also dont forget stuff that is on pay tv like entourage, got every episode of that, rescue me is one i think that dosn't air in aus at all, and of course there are old shows, i have every episode of scrubs and the office, the list goes on!
Torrents are good for these, serach for shows on www.torrentz.com and use utorrent to download.
I do believe this is where to get it http://www.mininova.org/tor/1168374
Will up date soon when i have it.
EDIT
That one is shyte, get this one http://www.mininova.org/tor/1168551
Edited by W0rp3D
    • I don't run the spring but it means you need to set your own belt tension.  I put tensioners on both sides too.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
