sorry, cant help till tonight (car at home)
dont have measurements for front/rear springs either
anyone?
if you get stuck install the shocks etc, and if it is too low or too high simply jack up each wheel one by one, spring clamp x 2 and tighten up, then release the circlip and reposition. you dont need to uninstall everything, just use 2x spring clamps, and do it slowly.
GLHF
https://www.sau.com.au/forums/topic/205638-urgent/#findComment-3639987
350mm centre of wheel to guard lip.
sk bilstein look to be set at the 3rd lowest circlip, could be the 4th lowest mark.
sorry, cant kneel to look properly, went by feel on the gruves.
if you like the car low then try the 3rd from bottom circlip gruve. should be the 350mm mark, if not then 345mm. mine would look awesome at 345mm IMO, but SA laws state that 350 is the min distance.
https://www.sau.com.au/forums/topic/205638-urgent/#findComment-3642262
hey all
i need to know asap which circlips will give what height using SK's shocks/springs. Also would be helpful to know how many MM front/rear the springs are shorter...
-Ryan
The standard groove, identified by the paint, gives 340 mm front and 320 mm rear when used with the Whiteline springs . That's after the usual settling in period of 1,000 k's or so. Each groove is 8 mm apart, so the recomended height (355/345) would require moving the circlip up 2 grooves on the front and 3 grooves on the rear. If you carry rear passengers often, have a sub abnd/or tow then I would suggest going up 4 grooves on the rear.
Cheers
Gary
https://www.sau.com.au/forums/topic/205638-urgent/#findComment-3642348
ended up using a lathe and getting 365 front, 370rear. i have sub/amp/dogs/mates/weekend luggage so thought higher would be better... we did it by guesswork and basic tape measure skillz... Can anyone tell me why i have 3 bumpstops?
https://www.sau.com.au/forums/topic/205638-urgent/#findComment-3643319
just $20 spring clamps
they arnt mine, a mate helped me put the suspn stuff on over 2yrs ago now.
we installed it, then dropped each corner by another circlip
mind you this bloke was an employee of ASE (adelaide suspn engineering?) for 9yrs, so he knew where to cut corners :)
https://www.sau.com.au/forums/topic/205638-urgent/#findComment-3644069
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
