oh yeah but a skyline can loose to a wrx! if it's a gtst v sti
Been there, done that. (on a SAU cruse out gawler way)
You should have seen the face on the STi driver as we pulled past him in a GTSt sedan (and he started infront) LOL
  • Replies 51
Posted Images
I have a few problems with this story:
1: - like the skyline wouldnt cain the WRX
2: - if the WRX was winning (ie the skyline was loosing) how did it swerve (obviously from behind - otherwise he wasnt loosing) and make the car in front loose control. I would have thought that only the car infront could make that move unless a car behind clips the rear bar.
3: - like the skyline wouldnt cain the WRX (i realise this piont is repeated, but its such a big error it deserves to be mentioned twice)
Thought I'd make a point here. If the guy in the Skyline was behind, but not a full car length behind, all he had to do was swerve & tap the other car. Generally the front end of a car is more stable at speed than the rear. Just look at some of the tin-top racing & 9 times out of 10 it's the car in front that goes into the bushes.
Alternatively they could have been slowing down from an even higher speed & the Skyline caught up.... If it was a Skyline, I'm still confused as to what's the truth here.
in the pictures on the link given it shows, a grey hound bus, a old camry, a smooshed rex and an ugly looking dark green soarer with an unpainted bodykit.
the only maroon car on there was the (now, convertible) camry.
anything that involves races in the paper, it seems like it HAS to be a skyline even if it isnt true.
cambodians and vietnamese's have been rival gangs up that way. so maybe one car was running from the other and thats why he smashed into the rex to take him out. or am i thinking to much to be a newspaper reporter....
You go to the top of the class Kye :) ........let me know if you're ever looking for a career change.
Wouldn't suprise me if that was spot on with all the stuff in the papers in the last fortnight about these 2 rivals.
actually i am looking for a new job haha
stop teaching us youngins your bad ways!!
gotta love some of the 1 eyed call's on here, 'sif a skyline can get beaten by a wrx' WTF is wrong with ppl these days, seriously YES a wrx can be faster then a skyline, and dont say anything bad about ns.com considering SAU REXNET AUSROTA ect ect ect are just as full of clueless ppl :)
i got no idea wats going on with the asian stuff, also did ppl also think that there were many cars that pulled over to help/look at the crash many imports heading to the drift praccy so the soarer pictured could have been anyones, cops most prob got there defect books out on anyone that tried to help.
4door_sleeper: let me know where you got the side skirts n rear pods from as i maybe gettin a 4 door to putt around in, cheers
gotta love some of the 1 eyed call's on here, 'sif a skyline can get beaten by a wrx' WTF is wrong with ppl these days, seriously YES a wrx can be faster then a skyline, and dont say anything bad about ns.com considering SAU REXNET AUSROTA ect ect ect are just as full of clueless ppl :domokun:
u see... ns.com people THINK they know shitz but really...----> :) ! they dont evan know how to short type words and spell everything out letter for letter -,-" geesss 21st century helloOOooOO just imagine sms'in on their phones... will be like 5 pages long to say hi or somethin.
WTF are you talking about...
are you just unhappy that you got drilled on there?
QUOTE(kietz0007 @ Feb 11 2008, 11:55 PM) *
lol dats preety daring swerving ur car into another lol i woudlnt do dat shit to my car ahahha
QUOTE(BillyE @ Feb 11 2008, 10:26 PM) *
really? you wouldnt????
wow i thought most people would
why wouldnt u?
QUOTE(kietz0007 @ Feb 11 2008, 11:58 PM) *
and why would YOU?
QUOTE(MR 1JZ @ Feb 12 2008, 8:09 AM) *
the point bill is trying to make is that you do not have the mental capabilities to post with the rest of society on an internet forum, so for everyones sake please stop...
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
