I put my set on today, on an R32 gtst.
Front: 18x8.5 +29 with 225/40/18
Rear: 18x9.5 +35 with 235/40/18
Hey Aaron, i noticed you didnt put the centre caps on , i too personally would prefer a different style cap, i even tried the rays 57's caps but doesnt fit.
  • Replies 126
Had my shadow silvers fitted yesterday on my R34 GTT looks a treat , peep my gallery
got a set of rays lock nuts to keep em on.
i also fitted some anodised blue 'works' nuts which is the same company as rays right?
Yeah, i think they look better with no centre caps.
What offsets did you get for your gtt?
Hi mate,
how u go with +29 offset at the fronts? rubbing the front guards?
They don't rub on anything. close to the inside end of the side skirt but no issues yet.
Are the DTM Rush Shadow Silver still available? Is it possible to get them with tyres as well?
I'm after a set of these for a Series 2 R33 GTSt, but I'm not sure on the measurements that would fit. My aim is to fill out the guards as much as possible without having to make any body modifications.
Any help will be greatly appreciated. ;)
when i ordered mine i rang them direct from their website http://www.accessauto.com.au/ & i spoke to adrian and steve...maybe they have run out of stock? that is my guess
Yeah i guess so?!
I cant see the pics either
I cant believe this, ive asked twice for the payment details, and ive sent a PM with my mobile number asking for contact, and got none.
Hi N1
Sorry if there has been an issue I replied ur PMs i dont know if there has been an issue with the PMs at all sorry for inconvienience but they have been replied. As per PMs please send email enquiries as bank details are PDF and have issues in the PM attachments for some reason or ph 03 9873 0133
i setup an account with photobucket as recommended by N1GTR!
finally...here are the pics of my gtr with 18x9.5+25 offset :teehee:
im fitting the factory side skirts as i think that the current side skirts hide the shape of the car & the 'fatness' of the new wheels!
Hey ive ordered these rims for my 32 gtr could someone please photo chop this car to white for me... cheers.
also Marko are these you got the shadow silver?
yes they are shadow silver - what colour u getting? they would get great on a white gtr
i have since taken off the gay centre caps - look much tougher without them
Edited by Marko R1
Hi N1
I will call after the long weekend
  • 1 month later...
Hi Guys
Now available Satin Black powder coat and ONYX Pearl (dark gunmetal) powder coat for the DTM Rush and Z7s. Rush Pictured in Satin Black and Z7 in ONYX Pearl
Satin Black additional $110 per set
ONYX Pearl additional $150 per set
allow 7-10 days for process
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
