Item: SUPER ADVAN RIMS
Age: UNKNOWN
Condition: REASONABLE TYRES ARE SUITABLE FOR BURNOUTS
Price: $500
To Fit: (What car) ANYTHING WITH 5x114.3 WILL SUIT SKYLINE/SUPRA ETC ETC
Contact: 0403519252
Comments: VERY LIGHT WEIGHT WHEELS GUYS GOOD FOR TRACK WORK
STAGGERED SET WITH 5x114.3
FRONT - 16x7 +32
REAR - 16x8 +32
REASONABLE CONDITION WITH SCRATHES HERE AND THERE BUT THEY ARE SERIOUSLY LIGHT WEIGHT
PRICE NEGOTIABLE
IM ALSO WILLING TO SWAP FOR A HKS SSQV BOV AND/OR SOME DEFI (OR THE NEW AUTOGAUGE) GAUGES, AFTERMARKET ECU, SAFC, ELECTRONIC BOOST CONTROLLER, POD FILTER, CATCH CAN ETC ETC OR MR2 TURBO PARTS WITH CASH ADJUSTMENT IF NEEDED
Edited by purple5ive
https://www.sau.com.au/forums/topic/205663-super-advan-16s-500/
sorry mate 350 is too low
these rims are selling for 700 upwards with ok condition tyres so 500 is a good price for them
make me a decent offer and u can have them
tyres arent the best wont pass rwc i can get good condition used tyres for them though if ur interested for under 150
im located in franston area
  • 3 months later...
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
